'An old friend of mine, flew a Fairchild 24R46 out of Chicago. His motor, as regular as clockwork, used 1 gallon of oil per hour. Never had a sign as to why it did it. No oil on the belly, and the exhaust was clean. Flew for 3 hours, stopped and put in 3 gallons. Flew 3 more hours, put in 3 gallons and topped off the fuel. As long as he flew behind that motor, he carried 1 to 2 cases of oil. He did all of the usual checks, and never had a clue why it used a lot of oil.You might see a photo of his airplane around the mid to late 60's. He had a little control problem on landing. There was a Cessna 150 on the back of the fuselage. The prop came through the cabin, just behind station 3.Bob
On Thursday, June 11, 2015 2:40 AM, "'Airy-H. Millet'
flyingairy@hotmail.com [fairchildclub]" wrote:
by the way:
when inside pressure grow up into the crankcase..
every accessories / accessories bearing may become to leak...
thus you may notice that the original Generator on the back side of the engine as a small hole, which can evacuate oil leaks through its bearings when it happens. (and if generator is not well assembled, it will be full of oil one day).
Airy
fairchildclub@yahoogroups.com
Date: Thu, 11 Jun 2015 09:17:20 +0100
Subject: RE: [fairchildclub] Re: Oil consumption on Ranger engine
There is on mine - Ex military Argus - the venturies, not connected to
anything, were there 'just for show' I think.
Frank
fairchildclub@yahoogroups.com [mailto:
fairchildclub@yahoogroups.com]
Sent: 11 June 2015 08:00
To: fairchildlist
there are no vacuum pump on Ranger engines usually!
_____
Date: Wed, 10 Jun 2015 19:53:49 -0700
Subject: [fairchildclub] Re: Oil consumption on Ranger engine
Dan
Just a thought---
I had a vacuum pump seal failure cause sudden oil use.
Especially coming out the breather due to the crankcase pressure that it
created.
Cheers,
Lonnie Woodard
#ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453 -- #ygrps-yiv-1154930283yiv3954044453ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mkp #ygrps-yiv-1154930283yiv3954044453hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mkp #ygrps-yiv-1154930283yiv3954044453ads { margin-bottom:10px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mkp .ygrps-yiv-1154930283yiv3954044453ad { padding:0 0;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mkp .ygrps-yiv-1154930283yiv3954044453ad p { margin:0;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mkp .ygrps-yiv-1154930283yiv3954044453ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-sponsor #ygrps-yiv-1154930283yiv3954044453ygrp-lc { font-family:Arial;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-sponsor #ygrps-yiv-1154930283yiv3954044453ygrp-lc #ygrps-yiv-1154930283yiv3954044453hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-sponsor #ygrps-yiv-1154930283yiv3954044453ygrp-lc .ygrps-yiv-1154930283yiv3954044453ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453activity span { font-weight:700;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453activity span span { color:#ff7900;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453activity span .ygrps-yiv-1154930283yiv3954044453underline { text-decoration:underline;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 .ygrps-yiv-1154930283yiv3954044453attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 .ygrps-yiv-1154930283yiv3954044453attach div a { text-decoration:none;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 .ygrps-yiv-1154930283yiv3954044453attach img { border:none;padding-right:5px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 .ygrps-yiv-1154930283yiv3954044453attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 .ygrps-yiv-1154930283yiv3954044453attach label a { text-decoration:none;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 .ygrps-yiv-1154930283yiv3954044453bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 .ygrps-yiv-1154930283yiv3954044453bold a { text-decoration:none;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 dd.ygrps-yiv-1154930283yiv3954044453last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 dd.ygrps-yiv-1154930283yiv3954044453last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 dd.ygrps-yiv-1154930283yiv3954044453last p span.ygrps-yiv-1154930283yiv3954044453yshortcuts { margin-right:0;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 div.ygrps-yiv-1154930283yiv3954044453attach-table div div a { text-decoration:none;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 div.ygrps-yiv-1154930283yiv3954044453attach-table { width:400px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 div.ygrps-yiv-1154930283yiv3954044453file-title a, #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 div.ygrps-yiv-1154930283yiv3954044453file-title a:active, #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 div.ygrps-yiv-1154930283yiv3954044453file-title a:hover, #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 div.ygrps-yiv-1154930283yiv3954044453file-title a:visited { text-decoration:none;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 div.ygrps-yiv-1154930283yiv3954044453photo-title a, #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 div.ygrps-yiv-1154930283yiv3954044453photo-title a:active, #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 div.ygrps-yiv-1154930283yiv3954044453photo-title a:hover, #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 div.ygrps-yiv-1154930283yiv3954044453photo-title a:visited { text-decoration:none;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 div#ygrps-yiv-1154930283yiv3954044453ygrp-mlmsg #ygrps-yiv-1154930283yiv3954044453ygrp-msg p a span.ygrps-yiv-1154930283yiv3954044453yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 .ygrps-yiv-1154930283yiv3954044453green { color:#628c2a;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 .ygrps-yiv-1154930283yiv3954044453MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 o { font-size:0;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453photos div { float:left;width:72px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453reco-category { font-size:77%;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453reco-desc { font-size:77%;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 .ygrps-yiv-1154930283yiv3954044453replbq { margin:4px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mlmsg select, #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 input, #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mlmsg pre, #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 code { font:115% monospace;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-mlmsg #ygrps-yiv-1154930283yiv3954044453logo { padding-bottom:10px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-msg p#ygrps-yiv-1154930283yiv3954044453attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-reco #ygrps-yiv-1154930283yiv3954044453reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-sponsor #ygrps-yiv-1154930283yiv3954044453ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-sponsor #ygrps-yiv-1154930283yiv3954044453ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-sponsor #ygrps-yiv-1154930283yiv3954044453ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-text { font-family:Georgia;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-text tt { font-size:120%;} #ygrps-yiv-1154930283 #ygrps-yiv-1154930283yiv3954044453 #ygrps-yiv-1154930283yiv3954044453ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1154930283
