Sent: Wed, February 9, 2011 6:04:49 AM
Subject: Re: [fairchildclub] Re: F24 Forward Upper Door Frame Upholstery
Bob,
If you make a drawing could you send me one-I don't have the balsa formers
wither. Just wondering-did you get an e-mial I sent you about the Wing Numbers?
Buell
Sent: Tuesday, February 8, 2011 9:05:04 PM
Subject: [fairchildclub] Re: F24 Forward Upper Door Frame Upholstery
I probably shouldn't ask, but you have the balsa pieces that are placed over the
fuel/electrical wires on the front side of the door post? They go from the
spruce piece that the fuel valve mounts to, then all the way up to the air vent
inlet.
I plan to run a 3" cotton tape, only 1 layer thick, from top to bottom around
the door post, fuel lines covered by the balsa. Then put the upholstery around
that. Then fasten the rear of the windshield frame back down.
You will need to watch how much fabric you wrap around the door post, because
all that material will push the windshield frame outward.
I don't remember if the 2 balsa pieces are shown in the CD.
Mine aren't installed, at this time. Making a drawing won't be a problem.
--- In fairchildclub@yahoogroups.com , "Frank" wrote:
> Folks,
> Does anyone have the secret to doing a tidy job with the upholstery for the
>front face of the upper forward door frames around the fuel and pitot/static
>pipes?
> I am finding it difficult working out how to achieve a neat appearance.
> All suggestions very gratefully received.
> Many thanks
> Frank Cox
> UC61K G-BCBL
BHP
