Re: Ranger Mods
Posted: Tue Nov 06, 2007 12:42 pm
'I'm with Curt.
Oil is cheeeeeeep.? Compared to the price of the plane and fuel,
how much oil you consume is only a logistic problem not a financial problem.
I have been know to take 25 quarts with me to travel to Oshkosh from Texas.?
That year, I got home with 1 quart and thought that was just OK.?
That is what you get with an engine designed in 1935.
I'm only on my 2nd Ranger powered plane, but drying it up is low
on my list.? Having fun with the plane is much more important.
Richard Smith
Sent: Tue, 6 Nov 2007 12:22 pm
Subject: [fairchildclub] Re: Ranger Mods
I suspect he means 1 -1.5 quarts per hour. If you do a search on
Ranger Oil Consumption in the messages, you'll find several
discussions on mods, oil use, etc.
I'm on my 4th Ranger, one had all the mods(drilled pistons with
chamfered ring groove, sludge plug o-rings, intake valve seals, tight
bearings, etc), one none, one some, and my latest with none. All
have used between 1-1.5 quarts depending on how hard they were being
pushed. I've not heard anyone real happy with anything but standard
rings.
I'm don't think much, if anything, is gained with the mods. Resign
yourself to using over a quart an hour and if you get a bit below
that be happy. That's just the way Rangers are.
The lowest reliable consumption I've ever heard of is .75 quarts/hour.
--- In fairchildclub@yahoogroups.com, "Mike Danielle"
Email and AIM finally together. You've gotta check out free AOL Mail! - http://mail.aol.com
Richard Smith
rings.
(above - it>
> Hmmmm.... Do you mean 1 to 1.5 PINTS per hour?
> MD
> From: "Robert Webster"
> Sent: Monday, November 05, 2007 5:54 PM
> Subject: Re: [fairchildclub] Ranger Mods
> > It is called the Menasco Mod and is a few holes drilled below
on the> > is an inverted engine) the oil ring on the pistons. No changes
break in> > cylinder. John Ferrero did mine (J&C Aircraft Engines) and after
know if> > about 50 hours I am down to 1 to 1.5 quarts per hour. I don't
------------> > John still has new pistons or not.
> > Bob Webster
> > From: Jan Servaites
> > Sent: Monday, November 05, 2007 5:30 PM
> > I know nothing about these Ranger mods. Would there be an on-line
> > article that talks about them?
> > Thanks in advance,
> > Jan
> > james chybicki wrote:
> > > I believe Ed Wagner in Sheboygan, Wisconsin
> > > does the Oil Modifications on the Ranger Pistons
Date:> >
> > No virus found in this incoming message.
> > Checked by AVG Free Edition.
> > Version: 7.5.503 / Virus Database: 269.15.22/1111 - Release
________________________________________________________________________> > 11/5/2007 4:36 AM
> > Yahoo! Groups Links
