mag. Is that shorting out the right mag or left mag? Lucky Mc Luckie
Sent: Monday, May 23, 2005 11:51 PM
Subject: Re: [fairchildclub] Ignition Harness
All:
Me, too — I have radio noise that goes away when I turn off the right
mag. Could someone enlighten me as to the procedure for diagnosing the
source of the noise?
> I solved the problem by going through and cleanin/replacing all of the
> grounding connections.
Are you referring to P-lead connections or spark wire connections?
> Everything except the harness has been ruled out. And we seem to have
> found the bad lead.
How do you identify a bad lead?
Thanks in advance,
:Dan Michael
