Re: Fuel tank level sender
Re: Air-oil separator
'What was the piston mod and do you have a way to show the routing of the
lines on the separator?
Gene Haines
Vintageaircraftgroup.org
Gene Haines
'The piston mod is described in detail in the club newsletter. It was designed
by Ed Wegner. My lines are simple, air on top, oil on the bottom. My
seperator is not mounted on the firewall, but just aft of the blow-by outlet.
'--- In fairchildclub@yahoogroups.com, plsurflyin@... wrote:
Could you let me know about the rerouting of the oil separator?
best regards
James'
line>
> Brad,
> do the piston mod by Ed Wegner. That and rerouting the oil separator
little under> reduced my oil consumption from a little over 1 GALLON per hour to a
Don sounds familiar.> 1 quart an hour.
> don
best regards
James'
'we just put it in correctly.
It has two out hoses. The should be vertical, not horizontal like mine were.
like this... (O)
(O)
not this (O) (O)
************************************** See what's free at http://www.aol.com
like this... (O)
(O)
not this (O) (O)
'Thanks ill have a look today.
james
like this... (O)
(O)
not this (O) (O)
james
like this... (O)
(O)
not this (O) (O)
'Which type of separator do you use?
I have a very big one installed,but do not think it works as it should.
Regards,
Remko
Regards,
Remko
mine were.
> like this... (O)
> (O)
> not this (O) (O)
http://www.aol.com
'Fairchild Group
If anyone with knowledge of where to obtain new lwvel
senders or a substitute for them I would appreciate
the info.
Have some engine parts for trade if someone would
rather do that,To much stuff to list.
Thanx
Harry
--- m51rs wrote:
Phone 904-284-4276
Fax 904-284-3869
Be a PS3 game guru.
Get your game face on with the latest PS3 news and previews at Yahoo! Games.
http://videogames.yahoo.com/platform?platform=120121'
the info.
Thanx
Harry
--- m51rs wrote:
Harry Hayman> Which type of separator do you use?
> works as it should.
> Regards,
> Remko
> horizontal like
> mine were.
> > like this... (O)
> > (O)
> > not this (O) (O)
> free at
> http://www.aol.com
> removed]
Phone 904-284-4276
Fax 904-284-3869
Be a PS3 game guru.
'Harry,
There are some Stewart Warner sender's that will work but, You may have to replace the gauges also.
John Berendt
Fairchild Club
John Berendt
Fairchild Club
Sent: Friday, June 08, 2007 10:49 AM
Subject: [fairchildclub] Fuel tank level sender
Fairchild Group
the info.
Thanx
Harry
> works as it should.
> Regards,
> Remko
> horizontal like
> mine were.
> > like this... (O)
> > (O)
> > not this (O) (O)
> free at
> http://www.aol.com
> removed]
Harry Hayman
Phone 904-284-4276
Fax 904-284-3869
Be a PS3 game guru.
'Thanx John
The gauges are 6Volt and have to be changed
out.Somewhere I have the part number's for the
Stewart/Warner gauges.I will keep searching.
Harry
--- fchld wrote:
Phone 904-284-4276
Fax 904-284-3869
Got a little couch potato?
Check out fun summer activities for kids.
http://search.yahoo.com/search?fr=oni_on_mail&p=summer+activities+for+kids&cs=bz'
Harry
--- fchld wrote:
__________________________________________________________> Harry,
> John Berendt
> Fairchild Club
> From: harry hayman
> Fairchild Group
> lwvel
> appreciate
> the info.
> Thanx
> Harry
> it
> > works as it should.
> > Regards,
> > Remko
> plsurflyin@...
> not
> > horizontal like
> > mine were.
> > > like this... (O)
> > > (O)
> > > not this (O) (O)
> what's
> > free at
> > http://www.aol.com
> > removed]
> Harry Hayman
> Phone 904-284-4276
> Fax 904-284-3869
Harry Hayman> Be a PS3 game guru.
> removed]
Phone 904-284-4276
Fax 904-284-3869
