Page 2 of 2
Re: transponder
Posted: Sun Oct 28, 2001 3:30 pm
by WALTER ALBERT
'a properly overhauled ranger and the use of 60 wt oil will normally not use
excessive oil...if you are seeing excessive out the breather you have other
problems.....walt
Sent: Sunday, October 28, 2001 9:40 AM
Subject: Re: [fairchildclub] transponder
> Well, we experimental guys sometimes route the breather tube to drip on
> the exhaust maifold to burn the excess oil. Here in Wisconsin (or at
> high altitudes) running the tube out back to the tailwheel has a
> problem. Besides oil, there is usually water vapor along with the oil
> and it ends up freezing and blocking the tube. When the pressure builds
> up enough, it vents through the engine front seal and creates any even
> bigger mess...especially in the pilot's shorts ;)
> Scott
> robert hensarling wrote:
> > -----Original Message-----
> > From: Scott
> > To: fairchildclub@yahoogroups.com
> > Date: Sunday, October 28, 2001 8:14 AM
> > I don't own any oil wells (my good friend Richard Smith has the monopoly
on
> > those), but maybe if I tie little buckets along the trailing edge of the
> > center section I can catch about 90% of the breather oil and recycle it.
> > Seriously, Richards 19 has a breather tube that runs the length of his
> > airplane, and exits just aft of the tailwheel. Seems like a great idea
and
> > solution to a messy problem. I'm always on my back cleaning the oil off
of
> > my airplane. Am I alone in this? Any other solutions/suggestions?
> > Robert Hensarling
> > http://www.mesquiterocker.com
> > Uvalde, Texas
> > >Rolling on the floor laughing! Technically, you can still get flight
> > >following (I have from Duluth, MN) without a transponder (also when I
> > >flew into Springfield, IL Class C). They have you make a turn to
> > >identify you then they provide info for you. I don't know if "Center"
> > >will do that, but the smaller airports with radar have always
> > >accomodated me and my little Corben :)
> > >Do you own an oil well there in Texas to keep that Ranger lubed? ;)
> > >Scott
> > >> From: Scott
> > >> Date: Sunday, October 28, 2001 7:56 AM
> > >> That's true Scott. Maybe I won't get one, but I do like flight
> > following.
> > >> Just seems safer if "Center" knows where I am, even when squawking
1200.
> > >> Will think about this some more. $1,000 will buy a weeks worth of
oil
> > for
> > >> my Ranger :o)
> > >> Robert Hensarling
> > >> Uvalde, Texas
> > >> >Well, you still wouldn't need a transponder, but you wouldn't be
exempt
> > >> >anymore from having one in Class B & C airspace or the mode C veils
> > >> >around the big cities. If you don't go there much, you could still
> > >> >leave out the transponder. That would save about $1000.
> > >> >Scott
> > >> >> From: jstreat360@aol.com
> > >> >> Date: Saturday, October 27, 2001 8:21 PM
> > >> >> Jamie, I'm having a Jasco put in.
> > >> >> Robert
> > >> >> >Robert,
> > >> >> >Are you going to install a full up Elec system or just the Batt
and
> > >> >> Starter.
> > >> >> >If no Alt or Gen install, then not required to have a
Transponder.
> > That
> > >> is
> > >> >> >the best $$ way out.
> > >> >> >Jamie S. Treat A&P/IA
> > >> >> >Visit my Web Site:
HREF="http://hometown.aol.com/ftreat9191/AIRCRAFTRESTORATIONREPAIRindex.html
> > >> >> ">Aircraft Restoration & Repair
> > >> >> >Meet my Family
HREF="http://hometown.aol.com/ftreat9191/TreatFamilyHomePage.html">Treat
> > >> >> Family Home Page
> > >> >> >[Non-text portions of this message have been removed]
> > >> >> >To unsubscribe from this group, send an email to:
> > >> >> >fairchildclub-unsubscribe@yahoogroups.com
> > >> >> >Your use of Yahoo! Groups is subject to
> > >> http://docs.yahoo.com/info/terms/
> > >> >Scott
> > >> >http://corbenflyer.tripod.com/
> > >> >Building RV-4
> > >> >Gotta Fly or Gonna Die!
> > >Scott
> > >Building RV-4
> Scott
> Building RV-4
Re: transponder
Posted: Sun Oct 28, 2001 3:35 pm
by WALTER ALBERT
'escessive oil out the breather should indicate problems within the engine. a
properly overhauled engine using 60 wt oil should not consume excessive oil
petcock....walt
Sent: Sunday, October 28, 2001 1:11 PM
Subject: RE: [fairchildclub] transponder
> When you get limited to 20 minute flights and have to land to fill the oil
> tank, call me, I got experience fixin it Bob Haas Buckingham,
> AAFB
> From: robert hensarling [mailto:rhrocker@hilconet.com]
> Sent: Sunday, October 28, 2001 9:19 AM
> From: Scott
on
and
of
> Robert Hensarling
> Uvalde, Texas
> >Scott
> >> From: Scott
> following.
1200.
> >> Will think about this some more. $1,000 will buy a weeks worth of oil
> for
> >> my Ranger :o)
> >> Robert Hensarling
> >> Uvalde, Texas
exempt
> >> >Scott
> >> >> Robert
> >> >> >Robert,
> >> >> >Are you going to install a full up Elec system or just the Batt and
> >> >> Starter.
> >> >> >If no Alt or Gen install, then not required to have a Transponder.
> That
> >> is
> >> >> >Visit my Web Site:
> >> >> >Meet my Family
> >> >> Family Home Page
> >> >Scott
> >> >Building RV-4
> >Scott
> >Building RV-4
Re: transponder
Posted: Sun Oct 28, 2001 4:33 pm
by robert hensarling
'-----Original Message-----
Date: Sunday, October 28, 2001 3:35 PM
I'm using almost 2 quarts per hour, sometimes less. Engine has about 230
hours since major.
How worried should I be? When should I have a "top" done?
Robert Hensarling
Uvalde, Texas
a
>petcock....walt
>From: Dorothy Haas
>To:
oil
>> AAFB
>> From: Scott
>on
>and
>of
>> Robert Hensarling
>> Uvalde, Texas
>> >Scott
>> >> From: Scott
>> following.
>1200.
>> for
>> >> my Ranger :o)
>> >> Robert Hensarling
>> >> Uvalde, Texas
>exempt
>> >> >Scott
>> >> >> Robert
>> >> >> >Robert,
and
>> >> >> Starter.
>> That
>> >> is
>> >> >> >Visit my Web Site:
l
>> >> >> >Meet my Family
>> >> >> Family Home Page
>> >> >Scott
>> >> >Building RV-4
>> >Scott
>> >Building RV-4
Re: transponder
Posted: Sun Oct 28, 2001 5:00 pm
by jstreat360@aol.com
'Robert,
Two qts an hour at 2250 is STD, the slower the engine speed the less your
going to use. Right now I'm only turning 2000 with the 0-93 Aeromatic, I put
a qt in about every three hours, I leak more than use. Bob Haas had an
engine that was not overhauled within standards when he purchased it and used
lots of oil ferrying it home to Fla. He has since rebuilt and is doing fine.
As for time to Major or Top, I go until it does not make compression or makes
metal. My old Ranger has been together since day one from the factory, never
a top, never a Cyl off. Been running 60 wt Mineral and 100 Oct. Pushing 700
TTSNEW and still makes 76/78 comp cold. The key is run them consistent and
run them often. An idle engine is its own worse enemy. Use that Marvel
Mystery oil and change the oil every 25 hours or sooner. I also have an ADC
Oil Filtration system approved via one time field, have not installed, will
do on next overhaul. The more you can clean up the oil the less the wear. Ed
Wegner has a separate oil filter system on his Ranger also.
Visit my Web Site:
Meet my Family
Re: transponder
Posted: Sun Oct 28, 2001 5:11 pm
Date: Sunday, October 28, 2001 5:00 PM
Seems like I'm in good shape then Jamie, my compressions are good. I do use
the MMO in the fuel, but haven't put any in the oil. I use the 60 wt. oil.
I'd be interested in learning about the oil filtering system eventually, if
the paperwork isn't a nightmare. Right now my 19 is at Robbie Vajdos strip
in Louise, Tx getting the electrical system installed (Robbie said the work
would only take a few days, but the paperwork would take a lot longer).
When I get it home I'll do an oil change, and try to find some of those
little copper crush washers, check the screens, and I'll be set for winter.
Flying here in South Texas during the winter months
isn't to bad, but it takes forever to warm up the oil.
Robert
>Robert,
put
used
fine.
makes
never
Ed
>Visit my Web Site:
Family Home Page
Re: transponder
Posted: Sun Oct 28, 2001 5:40 pm
by lov2fly28525@cs.com
'Robert,
Use an oil dipstick heater from your local NAPA Auto Parts Store. Plug it in
the night before and your oil will be 45 to 50 degrees when you start. I use
one in Idaho throuought the winter. Sure makes the warmups faster.
Al Rice
F-24W41A
NC28525
Re: transponder
Posted: Sun Oct 28, 2001 5:44 pm
Date: Sunday, October 28, 2001 5:40 PM
HEY! Now that's a neat idea Al, thanks! I usually spend at least 25
minutes getting the oil to temp, seems like that is hard on the engine also.
I'll give the stick a try.
Robert
>Robert,
in
use
>Al Rice
>F-24W41A
>NC28525
Re: transponder
Posted: Sun Oct 28, 2001 7:10 pm
'All,
Be careful on the oil dipsticks, get a good one. Some will get to hot and
burn the oil and you will have excessive wear of the metal parts. It will
break down the oil. The best way to go is the heated pad on the back side of
the tank. Bond it on, plug it in to the 110 socket and forget about it.
See the following web site for pad preheaters.
http://kennoncovers.com/aircraft_preheating_options.htm
Visit my Web Site:
Meet my Family
