Re: Warner 145 Question
Warner 145 Question
I have a problem that I am sure someone has confronted and solved. I have a spark plug seized in a spark plug boss. I've tried heat, Kroil, dry ice, no luck. Pins securing the boss in the head to prevent rotation sheared, boss is turning but plug absolutely stuck. I used anti-seize and nominal torque on installation and I am at a loss to explain how the plug is stuck so tight.
I am wondering if it would be a good idea to remove the plug and boss from the head, and replace with a new boss. I want to see if anyone has done this, or is there another way?
Thanks.
Bill McClure'
Thanks.
Bill McClure'
'Try talking with Daryl Turner IA , manager at Harrison Engine Svc. 219-362-9707 he is currently working on my Warner 165 cylinders and, is pretty knowledgeable on warner cylinder repairs. JP.Lorie
Newberry, Florida 32669
If you are not the intended recipient of this message (including attachments) or if you have received this message in error, immediately notify us and delete it as well as any attachments.
'I have a problem that I am sure someone has confronted and solved. I have a spark plug seized in a spark plug boss. I've tried heat, Kroil, dry ice, no luck. Pins securing the boss in the head to prevent rotation sheared, boss is turning but plug absolutely stuck. I used anti-seize and nominal torque on installation and I am at a loss to explain how the plug is stuck so tight. I am wondering if it would be a good idea to remove the plug and boss from the head, and replace with a new boss. I want to see if anyone has done this, or is there another way? Thanks. Bill McClure #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970 -- #ygrps-yiv-75214162yiv1947038970ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mkp #ygrps-yiv-75214162yiv1947038970hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mkp #ygrps-yiv-75214162yiv1947038970ads { margin-bottom:10px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mkp .ygrps-yiv-75214162yiv1947038970ad { padding:0 0;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mkp .ygrps-yiv-75214162yiv1947038970ad p { margin:0;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mkp .ygrps-yiv-75214162yiv1947038970ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-sponsor #ygrps-yiv-75214162yiv1947038970ygrp-lc { font-family:Arial;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-sponsor #ygrps-yiv-75214162yiv1947038970ygrp-lc #ygrps-yiv-75214162yiv1947038970hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-sponsor #ygrps-yiv-75214162yiv1947038970ygrp-lc .ygrps-yiv-75214162yiv1947038970ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970activity span { font-weight:700;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970activity span:first-child { text-transform:uppercase;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970activity span span { color:#ff7900;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970activity span .ygrps-yiv-75214162yiv1947038970underline { text-decoration:underline;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 .ygrps-yiv-75214162yiv1947038970attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 .ygrps-yiv-75214162yiv1947038970attach div a { text-decoration:none;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 .ygrps-yiv-75214162yiv1947038970attach img { border:none;padding-right:5px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 .ygrps-yiv-75214162yiv1947038970attach label { display:block;margin-bottom:5px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 .ygrps-yiv-75214162yiv1947038970attach label a { text-decoration:none;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 blockquote { margin:0 0 0 4px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 .ygrps-yiv-75214162yiv1947038970bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 .ygrps-yiv-75214162yiv1947038970bold a { text-decoration:none;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 dd.ygrps-yiv-75214162yiv1947038970last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 dd.ygrps-yiv-75214162yiv1947038970last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 dd.ygrps-yiv-75214162yiv1947038970last p span.ygrps-yiv-75214162yiv1947038970yshortcuts { margin-right:0;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 div.ygrps-yiv-75214162yiv1947038970attach-table div div a { text-decoration:none;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 div.ygrps-yiv-75214162yiv1947038970attach-table { width:400px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 div.ygrps-yiv-75214162yiv1947038970file-title a, #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 div.ygrps-yiv-75214162yiv1947038970file-title a:active, #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 div.ygrps-yiv-75214162yiv1947038970file-title a:hover, #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 div.ygrps-yiv-75214162yiv1947038970file-title a:visited { text-decoration:none;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 div.ygrps-yiv-75214162yiv1947038970photo-title a, #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 div.ygrps-yiv-75214162yiv1947038970photo-title a:active, #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 div.ygrps-yiv-75214162yiv1947038970photo-title a:hover, #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 div.ygrps-yiv-75214162yiv1947038970photo-title a:visited { text-decoration:none;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 div#ygrps-yiv-75214162yiv1947038970ygrp-mlmsg #ygrps-yiv-75214162yiv1947038970ygrp-msg p a span.ygrps-yiv-75214162yiv1947038970yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 .ygrps-yiv-75214162yiv1947038970green { color:#628c2a;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 .ygrps-yiv-75214162yiv1947038970MsoNormal { margin:0 0 0 0;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 o { font-size:0;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970photos div { float:left;width:72px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970reco-category { font-size:77%;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970reco-desc { font-size:77%;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 .ygrps-yiv-75214162yiv1947038970replbq { margin:4px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mlmsg select, #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 input, #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mlmsg pre, #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 code { font:115% monospace;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-mlmsg #ygrps-yiv-75214162yiv1947038970logo { padding-bottom:10px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-msg p#ygrps-yiv-75214162yiv1947038970attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-reco #ygrps-yiv-75214162yiv1947038970reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-sponsor #ygrps-yiv-75214162yiv1947038970ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-sponsor #ygrps-yiv-75214162yiv1947038970ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-sponsor #ygrps-yiv-75214162yiv1947038970ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-text { font-family:Georgia;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-text tt { font-size:120%;} #ygrps-yiv-75214162 #ygrps-yiv-75214162yiv1947038970 #ygrps-yiv-75214162yiv1947038970ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-75214162
'Or Al Holloway.
To: fairchildclub
Sent: Thu, Nov 14, 2013 11:02 am
Subject: Re: [fairchildclub] Warner 145 Question
To: fairchildclub
' THANKS TO BOTH. ANYONE WITH DIRECT EXPERIENCE OF THIS? BILL
'I spoke with Daryl on Friday, and you are right, he is very knowledgable on Warner's. He was able to provide the info I needed, and the likely reason it happened in the first place.
Thanks for the info.
Bill McClure
Sent from my iPad
Bill McClure
Sent from my iPad
#ygrps-yiv-1152439768 {word-wrap:break-word;background-color:#ffffff;}
Hi Bill,
Can you share with us what the end result was? I am curious as to the cause and cure.
Joe
Connected by DROID on Verizon Wireless
-----Original message-----
Hi Bill,
Joe
Sent: Sat, Nov 16, 2013 14:56:29 GMT+00:00
Bill McClure
Sent from my iPad
JP.Lorie
Thanks.
Bill McClure
'Was wondering if anyone would ask! He does believe the boss can be threaded out of the head, just be careful reinstalling the new bushing that it doesn't cross thread. The bushing is available from Fresno Airparts, and is P/N 2002, comes std, +.003 and +.006. The brass pin should go in a drilled hole that goes thru the threads of the bushing and the head. If secured this way much less likely for the bushing to turn. I don't think this bushing was drilled this way. As far as why the plug is stuck, he feels a burr might have come off the bushing and locked the threads. Maybe.
Don't know if others have had this problem, but I'd not seen it before.
Bill McC
Sent from my iPad
Hi Bill,
Joe
Bill McC
Sent from my iPad
On Nov 16, 2013, at 7:18 PM, Joe Preston wrote:
Hi Bill,
Joe
Bill McClure
Sent from my iPad
'Bill tell us of the likely cause so that we may attempt to avoid it if possible. JP.Lorie
#ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436 -- #ygrps-yiv-1091259223yiv0394131436ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mkp #ygrps-yiv-1091259223yiv0394131436hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mkp #ygrps-yiv-1091259223yiv0394131436ads { margin-bottom:10px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mkp .ygrps-yiv-1091259223yiv0394131436ad { padding:0 0;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mkp .ygrps-yiv-1091259223yiv0394131436ad p { margin:0;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mkp .ygrps-yiv-1091259223yiv0394131436ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-sponsor #ygrps-yiv-1091259223yiv0394131436ygrp-lc { font-family:Arial;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-sponsor #ygrps-yiv-1091259223yiv0394131436ygrp-lc #ygrps-yiv-1091259223yiv0394131436hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-sponsor #ygrps-yiv-1091259223yiv0394131436ygrp-lc .ygrps-yiv-1091259223yiv0394131436ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436activity span { font-weight:700;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436activity span span { color:#ff7900;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436activity span .ygrps-yiv-1091259223yiv0394131436underline { text-decoration:underline;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 .ygrps-yiv-1091259223yiv0394131436attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 .ygrps-yiv-1091259223yiv0394131436attach div a { text-decoration:none;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 .ygrps-yiv-1091259223yiv0394131436attach img { border:none;padding-right:5px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 .ygrps-yiv-1091259223yiv0394131436attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 .ygrps-yiv-1091259223yiv0394131436attach label a { text-decoration:none;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 .ygrps-yiv-1091259223yiv0394131436bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 .ygrps-yiv-1091259223yiv0394131436bold a { text-decoration:none;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 dd.ygrps-yiv-1091259223yiv0394131436last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 dd.ygrps-yiv-1091259223yiv0394131436last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 dd.ygrps-yiv-1091259223yiv0394131436last p span.ygrps-yiv-1091259223yiv0394131436yshortcuts { margin-right:0;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 div.ygrps-yiv-1091259223yiv0394131436attach-table div div a { text-decoration:none;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 div.ygrps-yiv-1091259223yiv0394131436attach-table { width:400px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 div.ygrps-yiv-1091259223yiv0394131436file-title a, #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 div.ygrps-yiv-1091259223yiv0394131436file-title a:active, #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 div.ygrps-yiv-1091259223yiv0394131436file-title a:hover, #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 div.ygrps-yiv-1091259223yiv0394131436file-title a:visited { text-decoration:none;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 div.ygrps-yiv-1091259223yiv0394131436photo-title a, #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 div.ygrps-yiv-1091259223yiv0394131436photo-title a:active, #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 div.ygrps-yiv-1091259223yiv0394131436photo-title a:hover, #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 div.ygrps-yiv-1091259223yiv0394131436photo-title a:visited { text-decoration:none;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 div#ygrps-yiv-1091259223yiv0394131436ygrp-mlmsg #ygrps-yiv-1091259223yiv0394131436ygrp-msg p a span.ygrps-yiv-1091259223yiv0394131436yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 .ygrps-yiv-1091259223yiv0394131436green { color:#628c2a;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 .ygrps-yiv-1091259223yiv0394131436MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 o { font-size:0;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436photos div { float:left;width:72px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436reco-category { font-size:77%;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436reco-desc { font-size:77%;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 .ygrps-yiv-1091259223yiv0394131436replbq { margin:4px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mlmsg select, #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 input, #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mlmsg pre, #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 code { font:115% monospace;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-mlmsg #ygrps-yiv-1091259223yiv0394131436logo { padding-bottom:10px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-msg p#ygrps-yiv-1091259223yiv0394131436attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-reco #ygrps-yiv-1091259223yiv0394131436reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-sponsor #ygrps-yiv-1091259223yiv0394131436ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-sponsor #ygrps-yiv-1091259223yiv0394131436ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-sponsor #ygrps-yiv-1091259223yiv0394131436ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-text { font-family:Georgia;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-text tt { font-size:120%;} #ygrps-yiv-1091259223 #ygrps-yiv-1091259223yiv0394131436 #ygrps-yiv-1091259223yiv0394131436ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1091259223Was wondering if anyone would ask! He does believe the boss can be threaded out of the head, just be careful reinstalling the new bushing that it doesn't cross thread. The bushing is available from Fresno Airparts, and is P/N 2002, comes std, +.003 and +.006. The brass pin should go in a drilled hole that goes thru the threads of the bushing and the head. If secured this way much less likely for the bushing to turn. I don't think this bushing was drilled this way. As far as why the plug is stuck, he feels a burr might have come off the bushing and locked the threads. Maybe.
Bill McC
Sent from my iPad
Hi Bill,
Joe
-----Original message-----From: Bill McClure
Bill McClure
Sent from my iPad
'Sorry, the info was here but, I hadn't seen it.Thanks JP.Lorie
#ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 -- #ygrps-yiv-845225318yiv8028376872ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mkp #ygrps-yiv-845225318yiv8028376872hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mkp #ygrps-yiv-845225318yiv8028376872ads { margin-bottom:10px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mkp .ygrps-yiv-845225318yiv8028376872ad { padding:0 0;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mkp .ygrps-yiv-845225318yiv8028376872ad p { margin:0;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mkp .ygrps-yiv-845225318yiv8028376872ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-sponsor #ygrps-yiv-845225318yiv8028376872ygrp-lc { font-family:Arial;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-sponsor #ygrps-yiv-845225318yiv8028376872ygrp-lc #ygrps-yiv-845225318yiv8028376872hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-sponsor #ygrps-yiv-845225318yiv8028376872ygrp-lc .ygrps-yiv-845225318yiv8028376872ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872activity span { font-weight:700;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872activity span:first-child { text-transform:uppercase;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872activity span span { color:#ff7900;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872activity span .ygrps-yiv-845225318yiv8028376872underline { text-decoration:underline;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 .ygrps-yiv-845225318yiv8028376872attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 .ygrps-yiv-845225318yiv8028376872attach div a { text-decoration:none;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 .ygrps-yiv-845225318yiv8028376872attach img { border:none;padding-right:5px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 .ygrps-yiv-845225318yiv8028376872attach label { display:block;margin-bottom:5px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 .ygrps-yiv-845225318yiv8028376872attach label a { text-decoration:none;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 blockquote { margin:0 0 0 4px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 .ygrps-yiv-845225318yiv8028376872bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 .ygrps-yiv-845225318yiv8028376872bold a { text-decoration:none;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 dd.ygrps-yiv-845225318yiv8028376872last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 dd.ygrps-yiv-845225318yiv8028376872last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 dd.ygrps-yiv-845225318yiv8028376872last p span.ygrps-yiv-845225318yiv8028376872yshortcuts { margin-right:0;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 div.ygrps-yiv-845225318yiv8028376872attach-table div div a { text-decoration:none;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 div.ygrps-yiv-845225318yiv8028376872attach-table { width:400px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 div.ygrps-yiv-845225318yiv8028376872file-title a, #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 div.ygrps-yiv-845225318yiv8028376872file-title a:active, #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 div.ygrps-yiv-845225318yiv8028376872file-title a:hover, #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 div.ygrps-yiv-845225318yiv8028376872file-title a:visited { text-decoration:none;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 div.ygrps-yiv-845225318yiv8028376872photo-title a, #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 div.ygrps-yiv-845225318yiv8028376872photo-title a:active, #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 div.ygrps-yiv-845225318yiv8028376872photo-title a:hover, #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 div.ygrps-yiv-845225318yiv8028376872photo-title a:visited { text-decoration:none;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 div#ygrps-yiv-845225318yiv8028376872ygrp-mlmsg #ygrps-yiv-845225318yiv8028376872ygrp-msg p a span.ygrps-yiv-845225318yiv8028376872yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 .ygrps-yiv-845225318yiv8028376872green { color:#628c2a;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 .ygrps-yiv-845225318yiv8028376872MsoNormal { margin:0 0 0 0;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 o { font-size:0;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872photos div { float:left;width:72px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872reco-category { font-size:77%;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872reco-desc { font-size:77%;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 .ygrps-yiv-845225318yiv8028376872replbq { margin:4px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mlmsg select, #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 input, #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mlmsg pre, #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 code { font:115% monospace;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-mlmsg #ygrps-yiv-845225318yiv8028376872logo { padding-bottom:10px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-msg p#ygrps-yiv-845225318yiv8028376872attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-reco #ygrps-yiv-845225318yiv8028376872reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-sponsor #ygrps-yiv-845225318yiv8028376872ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-sponsor #ygrps-yiv-845225318yiv8028376872ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-sponsor #ygrps-yiv-845225318yiv8028376872ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-text { font-family:Georgia;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-text tt { font-size:120%;} #ygrps-yiv-845225318 #ygrps-yiv-845225318yiv8028376872 #ygrps-yiv-845225318yiv8028376872ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-845225318Bill tell us of the likely cause so that we may attempt to avoid it if possible. JP.Lorie
Bill McC
Sent from my iPad
Hi Bill,
Joe
Bill McClure
Sent from my iPad
Further to this conversation, I obtained the 145 spark plug bushings from Harman Dickerson. Fresno Airparts had bushings, but the OD was too large. The nominal OD for the 145 is .938 . Harman had the brass bushings and steel pins. What I also found was that the front bushings were all pinned in two places opposite to each other, and with steel pins. The rear ones (the ones hard to get to!) were pinned in one spot with a relatively soft brass pin. I believe that is the cause of all this trouble. Still not completely done, having trouble getting the new bushing to seat all the way down.
Bill McClure
Bill McClure
Bill McC
Sent from my iPadOn Nov 16, 2013, at 7:18 PM, Joe Preston wrote:
Hi Bill,
Joe
Bill McClure
Sent from my iPad
