Re: Stuck exhaust valve (Ranger)
Tom Downey
Address Book
'Due to my computer crash, and replacement of the gizzmo what remembers
these things, my e-mail address book is blank. If you wish to be
included in my address file please send me a E-mail and I'll pick you
up.
Sorry for the inconvenience
Tom Downey ias*whidbey.net'
up.
Re: Address Book
'-----Original Message-----
On Behalf Of Tom Downey
Sent: Friday, July 08, 2005 9:46 AM
Subject: [fairchildclub] Address Book
up.
Yahoo! Groups Links'
up.
Buell Powell
Re: Address Book
'Hi John,
Please put my address back in your computer.
Buell Powell
Buell Powell
Sent: Friday, July 08, 2005 3:55 PM
Subject: RE: [fairchildclub] Address Book
> up.
Re: Address Book
'Tom,
The clubs address is fchld@rconnect.com.
Sent: Friday, July 08, 2005 9:45 AM
> up.
J. E. Miller
Re: Address Book
'Please add me to your address list. Thanks, Joe.
Sent: Friday, July 08, 2005 4:55 PM
> up.
harry hayman
'Has anyone out there in Ranger country come up with a
way to free up a stuck Ranger exhaust valve without
dismantling thr engine?
Thanx in advance.
Harry
--- "J. E. Miller" wrote:
Phone 904-284-4276
Fax 904-284-3869
Do You Yahoo!?
http://mail.yahoo.com'
Thanx in advance.
Harry
Harry Hayman> Please add me to your address list. Thanks, Joe.
> From: "JOHN"
> you wish to be
> > up.
> > Yahoo! Groups Links
> > Yahoo! Groups Links
Phone 904-284-4276
Fax 904-284-3869
Do You Yahoo!?
John Amundsen
'I ran some Marvel Mystery Oil in the crankcase for about five hours hard, as well as the same oil in the gasoline, 4 oz per 10 gal. That didn't immediately free it up so I took the cam cover off and staked the valves. That freed up the valves and I haven't had trouble since. I'm sure there are some others out there that can give you some more detailed advice.
Sent: Saturday, July 09, 2005 5:48 PM
Subject: [fairchildclub] Stuck exhaust valve (Ranger)
Thanx in advance.
Harry
> From: "JOHN"
> you wish to be
> > up.
> > Yahoo! Groups Links
> > Yahoo! Groups Links
Harry Hayman
Phone 904-284-4276
Fax 904-284-3869
Do You Yahoo!?
SPONSORED LINKS Aviation Warner Model planes
Plane fare Plane tickets Cheap plane tickets
YAHOO! GROUPS LINKS
'I don't know if this will help you. It is my experience with a 180 hp
Franklin having the same problem, sort of. I only had 3 exhaust valves in
various stages of sticking.
I pulled the valve cover off, and the rocker arm assembly off. Then
removed the bottom sparkplug, to gain access to the exhaust valve stem from
inside the cylinder. Since the valve was stuck the next part was fairly
easy. I remove the valve spring keeper and springs from the valve. I then
started tapping the valve with the butt of a screw driver, to move it back
into the cylinder. Once I got the tip of the valve flush with the valve
guide, I reached through the sparkplug hole and grabbed the valve stem with
a set of mechanical fingers (two finger variety) so I would have some
control of the valve should I drive the stem completely out of the valve
guide.
What I found was the inside of the valve guide was coated with a thin
crust of burnt oil. It had a dark amber/brown look to it. I then took a
pair of tweezers that had a well rounded tip on it, and rubbed it over the
crust with a moderate pressure and was able to break up the crust. I used
just enough pressure to break the crust and used a rounded tool so I
wouldn't scratch the valve guide or remove any metal.
For further information, I tried Marvel Mystery Oil, and about every
idea that any one would come up with. The colder the motor was, the worse
they stuck. Over time, it only got worse. I did make a fixture that I
bolted to the head that enabled me to collapse the valve springs so I could
get the keepers off.
After I got to the point that I knew what I was doing, it took
approximately 1 hour from start to finish to free up one exhaust valve.
Bob Etter
PO Box 974
Tonopah, NV 89049
775-482-6820
rletter@citlink.net'
guide.
Bob Etter
PO Box 974
Tonopah, NV 89049
775-482-6820
harry hayman
'Bob, Thanx so very much your sharing the info on
sticking valve's.The Ranger is different than the
Franklin,it does not have individual valve covers,ect.
It is an inline inverted engine.
Thanx again
Harry
PS if you already know this I am not trying yo insult
your intelligence
--- Robert Etter wrote:
Phone 904-284-4276
Fax 904-284-3869
Do You Yahoo!?
Thanx again
Harry
your intelligence
Harry Hayman> I don't know if this will help you. It is my
> assembly off. Then
> I would have some
> guide.
> rounded tool so I
> metal.
> doing, it took
> one exhaust valve.
> Bob Etter
> PO Box 974
> Tonopah, NV 89049
> 775-482-6820
> rletter@citlink.net
Phone 904-284-4276
Fax 904-284-3869
Do You Yahoo!?
harry hayman
'Hi John,
thanx for the info.I have a short nose fairchild and
the oil pump is jam up against the firewall,removing
the cam cover and resealing where the oilpump and the
cam cover matw is a bear.I have done this before,I do
pretty good for 78 year's old but working upside down
really is not my most favorite thing.But it looks like
the lesser of the evil's so in the AM I'll get
started.Have a good one,
Harry
--- John Amundsen wrote:
Phone 904-284-4276
Fax 904-284-3869
____________________________________________________
Sell on Yahoo! Auctions ? no fees. Bid on great items.
http://auctions.yahoo.com/'
Harry
------------------------------------------------------------------------------> I ran some Marvel Mystery Oil in the crankcase for
> detailed advice.
> From: harry hayman
> (Ranger)
> with a
> without
> Thanx in advance.
> Harry
> Joe.
> > From: "JOHN"
> > To:
> the
> If
> > you wish to be
> > > up.
> > > Yahoo! Groups Links
> > > Yahoo! Groups Links
> Harry Hayman
> Phone 904-284-4276
> Fax 904-284-3869
> Do You Yahoo!?
> protection around
> tickets
------------------------------------------------------------------------------> YAHOO! GROUPS LINKS
> web.
> email to:
Harry Hayman>
> removed]
Phone 904-284-4276
Fax 904-284-3869
