Re: gemme a brake part two/expander tube mat'l
robert hensarling
'I've got all my stuff together to do the brake bleeding process, as per the article John sent me. No problem on getting all the parts except the adapter that fits into the screw hole at the wheel. Dad took a 32 X 8 brass screw, about 1" long, and drilled a 1/16th" hole through it's entire length. Then I took a 2" piece of 1/4" copper tubing, and tapped the inside to fit the screw (a little loose), and JB welded the two pieces together. Now this goes into the hole at the wheel, and the 3/16's plastic tubing goes on the copper tubing, so I'm all set. I may try the system out tomorrow. I'm going to use dot 3 for now, just to get by, then when winter really sets in here in Texas (about 60 degrees), I'll flush the brake system with methyl ethyl alcohol (as per John), and use dot 5. I think I need to put some sort of compound on the threads of every connection when I do that.
Anyway, that's my story for now, will give an update when I try it out. You guys and gals have a Great Holiday Season!
Robert Hensarling
rhrocker@hilconet.com
www.mesquiterocker.com
Uvalde, Texas
Robert Hensarling
Uvalde, Texas
jstreat360@aol.com
'WARNING WARNING WARNING,
NO DOT THREE BRAKE FLUID, DOT 4 OR SWITCH TO DOT 5.
Visit my Web Site:
Meet my Family:
Visit my Web Site:
Meet my Family:
robert hensarling
Sent: Sunday, December 23, 2001 12:22 AM
Subject: Re: [fairchildclub] gemme a brake part two
Ok, I can do that. Is the Dot 3 corrosive? Do you have a suggestion for a
sealant for fittings Jamie when using Dot 5?
Thanks!
Robert
> Visit my Web Site:
> Meet my Family:
Family Home Page
Marge & John Berendt
'Bob
Dot 3 is a very good paint remover. And it is a bit on the corrosive side.
I use a sealer called "Tite Seal" I get it from Chief Aircaft Supply in
Grants Pass Oregon their phone is 800-447-3408. titeseal come in two
weights I use the medium weight Dot 5 will find every leak you have in the
system. I have one small leak but the amount does not bother. Also it does
not take off paint.
John Berendt.
not take off paint.
John Berendt.
Sent: Sunday, December 23, 2001 2:03 AM
> From:
a
> Thanks!
> Robert
> > Visit my Web Site:
HREF="http://hometown.aol.com/ftreat9191/AIRCRAFTRESTORATIONREPAIRindex.html
> > Meet my Family:
> > HREF="http://hometown.aol.com/ftreat9191/TreatFamilyHomePage.html">Treat
> Family Home Page
robert hensarling
Sent: Sunday, December 23, 2001 7:34 AM
Thanks John. What can you tell me about the Dot 4?
Robert
> Bob
side.
the
does
> not take off paint.
> John Berendt.
> From: "robert hensarling"
> > From:
> > To:
for
> a
> > Thanks!
> > Robert
> > > Visit my Web Site:
> > > Meet my Family:
> > Family Home Page
ranger440c5
'The discussion brake fluid is of interest. I am not sure if DOT3
itself is corrosive but it's biggest faults are it's superior paint
removal ability and it cannot hold moisture in suspension. DOT5 can
do this thus it produces less corrosion problems and doesn't make
that funky jelly. Hence DOT3 systems pool moisture in low points and
when saturated, a jell type translucent goo forms and exaserbates the
problem. Now as far as performance, I think DOT3 is superior in most
categories, boiling point(with rubber expander tubes????!!!),
expansion rate, and best of all it's sealing qualities. DOT5 will
creep forever, no problem for a flyer, but drives hangar queens and
clean freaks nuts. There is not much you can do about it, modern DOT5
applications have modern seals, flares, cylinders, etc., and seepage
is contained. DOT4&5 are popular with ABS and sophisticated system
user where corrosion and moisture problems are devestating.
DOT3 works well in a 24, thats what it came with, but you will also
note that they used to change it every year. That's what keeps DOT3
systems going. Change it every 12-24 months and all the moisture goes
with it. You just have to get good at bleeding brakes! DOT5 also works
well but unless you have a top notch sealed up system it will creep.
By the same token,unless the system is sealed up DOT3 will eat the
paint.
Now comes the question of what fluid to use if you have Cleveland
calipers(mil-5606 fluid) and Hayes masters (DOT3 originally)? HMMM.
There is also a unique bleeding technique available to expander tube
systems that old Cub mechanics use that works quite well. Anyone want
to hear it?'
paint.
to hear it?'
jstreat360@aol.com
'Robert,
DOT 3 will soften/destroy your expander tubes and master piston seals. For
conversion to DOT 5 (silicon based) Dow corning recommends RTV No. 730
solvent Resistant Sealant. Purge system with Denatured Alcohol or MEK. Watch
out for other mineral based thinners, will do damage. Make sure that system
is very very clean, any cross contamination will cause foaming action and
will render brake system spongy at best.
Make sure you placard next to the Master Res and make an entry in the
Airframe Log, highlight it. I also suggest you make up a Fluid list in the
back of the log telling you what fluids are going in what system. That will
help out the next person when you sell the aircraft. My 24R46 is running
three different fluids depending on what area.
Visit my Web Site:
Meet my Family:
Visit my Web Site:
Meet my Family:
seals. For> Robert,
730> conversion to DOT 5 (silicon based) Dow corning recommends RTV No.
MEK. Watch> solvent Resistant Sealant. Purge system with Denatured Alcohol or
that system> out for other mineral based thinners, will do damage. Make sure
action and> is very very clean, any cross contamination will cause foaming
the> will render brake system spongy at best.
in the> Airframe Log, highlight it. I also suggest you make up a Fluid list
That will> back of the log telling you what fluids are going in what system.
running> help out the next person when you sell the aircraft. My 24R46 is
> Visit my Web Site:
> Aircraft Restoration & Repair>
> Meet my Family:
> Tre
at Family Home Pageremoved]>
Whats wrong with regular old 5606 ?'
jstreat360@aol.com
'Skydrol 5606 is even worse for damage in the brake system parts. I have 5606
in my Tailwheel strut. Have Dot 4 in Main Gear Struts. Some people use, 5606,
Auto Trans Fluid and Motorcycle strut oil. All will work in the struts, not
brakes.
Visit my Web Site:
Meet my Family:
brakes.
Visit my Web Site:
Meet my Family:
robert hensarling
Sent: Sunday, December 23, 2001 10:26 AM
Ok, got it, thanks! I'm heading out to flush out the system with denatured
alcohol today, may put in the Dot 5 mananna.
Appreciate the help!
Robert
> Robert,
Watch
system
will
> Visit my Web Site:
> Meet my Family:
Family Home Page
