Brass coated aircraft nails
Posted: Tue Aug 16, 2022 12:13 am
by FairchildPT19mike
Wicks and Aircraft spruce no longer can get he small brass coated nails used for making ribs etc. I don't want to use staples. Anyone know of a soruce?? McMaster Carr doesn't have them either.
Mike at hotfoot149@gmail.com
Re: Brass coated aircraft nails
Posted: Tue Aug 16, 2022 3:55 pm
by Iterk@aol.com
As an old IA I’m not working on our KR yet but As with many things in our old aircraft, most of the supplies/technology comes from other cores. The brass nails are ‘ring nails’. Or ‘glue nails’ (the heat of driving them melts the glue and adds adhesion). These all come from boat building. You might look there. As for “legality”… if it is a proper working part of reasonable quality it is considered a “standard” part. A brass ring nail is a brass ring nail. Sorta’ like spruce. God does not have PMAs for trees. You have to look at 43-13 and decide. Google brass ring nails. Be sure you find the correct diameter. If you have the drawings it will be in the materials list. If you don’t have that reach out to me at iterk@aol.com and I’ll look at my KR/Parks dwgs. Wood rib nails were common.
Posted: Thu Aug 18, 2022 2:25 pm
by cvairwerks
Found a couple sources in Europe that say they have some in stock
Aircraft Nails (Gimp Pins) LAS Aerospace Ltd
www.lasaero.com www.lasaero.com
https://www.aircraftspruce.eu/a-c-nails ... 1-20-8.htm
https://www.partsbase.com/parts/AN30120 ... uctListing
