' I think that I saw someone mentioned drilling tiny holes all the way through the static line. I think that mine had two sets of holes, maybe 1/4" apart, front to back and rotated 90 deg. apart. The end was plugged with a soft rivet turned down to match the tube diameter. I used the smallest drill bit that I could find. I didn't know it at the time, mine was home made.
On ?Tuesday?, ?July? ?30?, ?2019? ?12?:?09?:?55? ?AM? ?PDT, Stuart Burgess
stuart@burgess.org.za [fairchildclub] wrote:
Hi David
I dont often log on to the group but follow the emails so I sent by reply
to the email address |I received from. I have included your email address
here so lets see if this works.
Cheers
Stuart
On Mon, 29 Jul 2019 at 17:09, Ranchaero Wing Shop
david@ranchaerowingshop.com [fairchildclub]
> Where I live here in California it's hard to find anyone doing plating
> anymore. Environmental regs I suspect. From watching Youtube videos, it
> doesn't seem like there's much to nickel plating. Make a non-conductive
> tank big enough to submerge the pitot tube, some chemical available on
> Amazon or you can make your own, some nickel electrode material, a small
> power supply. There's several Youtube videos demonstrating the process. I
> haven't tried it yet but I'm gathering up the materials.
> Stuart, where can I see your pics? I didn't receive any. Did you send them
> to me or the list? I must've missed them somehow.
> David
> On 7/28/19 11:16 PM, Stuart Burgess
> wrote:
> Hi David
> Glad you have a plan! I started out with the bits that I salvaged and ended
> up with a fully functional pitot. Could not find the thin walled brass tube
> for the body but fortunately what I found was the right OD but with a
> slightly thicker wall.
> All that remains is to have it plated. Apologies for the poor second pic.
> Only realised when I downloaded the pic that it had focused on the
> background but you get the idea.
> Stuart
> On Fri, 26 Jul 2019 at 17:58, Ranchaero Wing Shop
> wrote:
> > Thanks for your reply, Stuart. Unfortunately, the 1/2" brass tube shroud
> > was also trashed by the mechanic I took over this project from who did a
> > poor job of separating it from the tubes. But that's ok - I enjoy the
> > experience.
> > Since I posted my last message, my machinist tells me he can make those
> > slots with a tiny (1/32") end mill, and a little filing to square off the
> > ends of the slots with a jewelers file. So he will be doing that part for
> > me, except the filing.
> > I believe the entire assembly is finally nickel plated. I am studying
> this
> > process now at Youtube University. Doesn't look too difficult...
> > David
> > On 7/26/19 1:16 AM, Stuart Burgess
> > wrote:
> > Hi David
> > I had a similar problem so I got new brass tube for the body and new 1/4
> > inch copper tube for the static and dynamic pipes. I then disassembled my
> > old pitot discarding the pipework and reassembled the hardware like to
> nose
> > cone and the pitot itself onto the new pipes finally soldering it all
> back
> > into a new body tube. Worked great.
> > What is the condition of those bits like the shroud that you are trying
> to
> > remanufacture.
> > Cheers
> > Stuart
> > On Thu, 25 Jul 2019 at 23:58, Ranchaero Wing Shop
> > wrote:
> >> My pitot tube was seriously trashed, so after determining that finding a
> >> replacement was futile, I set about to make a new one. Nothing too
> >> challenging here, except...those (damn) 6 tiny little slots (static
> >> openings) in the rear section of the forwardmost 1/2" tube which is the
> >> static section of the tube. I hoped my machinist would have a good
> >> answer, but not so, yet. He's stumped too. How to cut those 6 tiny slots
> >> 1/4" long, about .030 wide, 2 rows of 3 slots spaced evenly around the
> >> circumference of the tube just aft of halfway back. A hacksaw blade just
> >> won't do a pretty job. I imagine maybe they were originally stamped. My
> >> water jet guy says his water jet is too brutal for such fine work.
> >> I suspect there's nothing magic about them, it's just static port. But
> >> they've gotta be pretty and look like the originals. One could probably
> >> drill a few little holes and achieve the same result, but 1st I need to
> >> exhaust all resources for doing an identical reproduction.
> >> Can anyone offer a creative possible solution?
> >> David
> > Kind regards
> > *Stuart Burgess*
> > *Cell: 0711998012*
> > *Email:
> Kind regards
> *Stuart Burgess*
> *Cell: 0711998012*
> *Email:
Kind regards
*Stuart Burgess*
*Cell: 0711998012*
*Email:
stuart@burgess.org.za *
#ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659 -- #ygrps-yiv-325112190yiv6733947659ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp #ygrps-yiv-325112190yiv6733947659hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp #ygrps-yiv-325112190yiv6733947659ads { margin-bottom:10px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp .ygrps-yiv-325112190yiv6733947659ad { padding:0 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp .ygrps-yiv-325112190yiv6733947659ad p { margin:0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp .ygrps-yiv-325112190yiv6733947659ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ygrp-lc { font-family:Arial;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ygrp-lc #ygrps-yiv-325112190yiv6733947659hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ygrp-lc .ygrps-yiv-325112190yiv6733947659ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity span { font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity span:first-child { text-transform:uppercase;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity span span { color:#ff7900;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity span .ygrps-yiv-325112190yiv6733947659underline { text-decoration:underline;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659attach div a { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659attach img { border:none;padding-right:5px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659attach label { display:block;margin-bottom:5px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659attach label a { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 blockquote { margin:0 0 0 4px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659bold a { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 dd.ygrps-yiv-325112190yiv6733947659last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 dd.ygrps-yiv-325112190yiv6733947659last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 dd.ygrps-yiv-325112190yiv6733947659last p span.ygrps-yiv-325112190yiv6733947659yshortcuts { margin-right:0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659attach-table div div a { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659attach-table { width:400px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659file-title a, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659file-title a:active, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659file-title a:hover, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659file-title a:visited { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659photo-title a, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659photo-title a:active, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659photo-title a:hover, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659photo-title a:visited { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div#ygrps-yiv-325112190yiv6733947659ygrp-mlmsg #ygrps-yiv-325112190yiv6733947659ygrp-msg p a span.ygrps-yiv-325112190yiv6733947659yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659green { color:#628c2a;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659MsoNormal { margin:0 0 0 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 o { font-size:0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659photos div { float:left;width:72px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659reco-category { font-size:77%;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659reco-desc { font-size:77%;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659replbq { margin:4px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg select, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 input, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg pre, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 code { font:115% monospace;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg #ygrps-yiv-325112190yiv6733947659logo { padding-bottom:10px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-msg p#ygrps-yiv-325112190yiv6733947659attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-reco #ygrps-yiv-325112190yiv6733947659reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-text { font-family:Georgia;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-text tt { font-size:120%;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-325112190 '
