Fairchild 24 Cabin Air Ventilator
Posted: Mon Jul 22, 2019 10:24 am
by Bart R.J. Decock
'Hi,
My Fairchild 24 is missing in the cabin, in the upper corners of the front windshield, the cabin air ventilator control (L + R) and the cabin air ventilator eyeball.(L+R)
Anyone of you guys know some for sale?
Bart
Re: Fairchild 24 Cabin Air Ventilator
Posted: Tue Jul 30, 2019 11:08 pm
by robert Etter
' I had the same problem that you have.  Mine happened to be in a box with some engine parts that was stolen.  About $2K in new Warner parts and several boxes of used parts that only had, at most, a couple 100 hours.  I still had the wood blocks that clamped around the diagonal tube which was nice.  I fabricated the mounting plate and ended up using a 90 deg.  1" dia. (I think) ABS elbow as a replacement.  Cut the female side at 45 deg. angle.  Then cut about 1/4" off the female collar.   The hole that I cut in the mounting place was just a tick larger than the male side diameter.  After mounting the plate, I put the male side through the plate and put the collar in the back side with a couple drops of cement.  I didn't put it on tight so it would rotate easily.  All of those areas between the windshield frame that the wood blocks (covered them with upholstery fabric), packed in a thin strip of felt to seal it off, to force the air through the home made ABS vent.In case you haven't done it, be sure to drill a drain hole in the inboard rear corner of the wings air box,....to drain any water when it rains.  You will need someone with really small hands.  I think I used 1 3/4" scat duct between the wing duct and the windshield frame.  Used RTV sparingly on both ends, but not at the ON/OFF rod.   My control rod was really tight, may need some future work to free it up.  I may need a flexible coupler on the rod between the wing and cabin.  There is no chance of finding my original vents.  All of the parts were destroyed in a flood at the airport on the North side of St Louis many years ago.If you can't find the OE vents, this may help.Bob
On ?Monday?, ?July? ?22?, ?2019? ?09?:?50?:?00? ?AM? ?PDT, 'Bart R.J. Decock' c47fleetmaster@yahoo.co.uk [fairchildclub] wrote:
Hi,
Bart
#ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984 -- #ygrps-yiv-100374934yiv3797456984ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mkp #ygrps-yiv-100374934yiv3797456984hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mkp #ygrps-yiv-100374934yiv3797456984ads { margin-bottom:10px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mkp .ygrps-yiv-100374934yiv3797456984ad { padding:0 0;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mkp .ygrps-yiv-100374934yiv3797456984ad p { margin:0;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mkp .ygrps-yiv-100374934yiv3797456984ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-sponsor #ygrps-yiv-100374934yiv3797456984ygrp-lc { font-family:Arial;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-sponsor #ygrps-yiv-100374934yiv3797456984ygrp-lc #ygrps-yiv-100374934yiv3797456984hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-sponsor #ygrps-yiv-100374934yiv3797456984ygrp-lc .ygrps-yiv-100374934yiv3797456984ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984activity span { font-weight:700;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984activity span:first-child { text-transform:uppercase;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984activity span span { color:#ff7900;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984activity span .ygrps-yiv-100374934yiv3797456984underline { text-decoration:underline;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 .ygrps-yiv-100374934yiv3797456984attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 .ygrps-yiv-100374934yiv3797456984attach div a { text-decoration:none;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 .ygrps-yiv-100374934yiv3797456984attach img { border:none;padding-right:5px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 .ygrps-yiv-100374934yiv3797456984attach label { display:block;margin-bottom:5px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 .ygrps-yiv-100374934yiv3797456984attach label a { text-decoration:none;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 blockquote { margin:0 0 0 4px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 .ygrps-yiv-100374934yiv3797456984bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 .ygrps-yiv-100374934yiv3797456984bold a { text-decoration:none;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 dd.ygrps-yiv-100374934yiv3797456984last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 dd.ygrps-yiv-100374934yiv3797456984last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 dd.ygrps-yiv-100374934yiv3797456984last p span.ygrps-yiv-100374934yiv3797456984yshortcuts { margin-right:0;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 div.ygrps-yiv-100374934yiv3797456984attach-table div div a { text-decoration:none;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 div.ygrps-yiv-100374934yiv3797456984attach-table { width:400px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 div.ygrps-yiv-100374934yiv3797456984file-title a, #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 div.ygrps-yiv-100374934yiv3797456984file-title a:active, #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 div.ygrps-yiv-100374934yiv3797456984file-title a:hover, #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 div.ygrps-yiv-100374934yiv3797456984file-title a:visited { text-decoration:none;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 div.ygrps-yiv-100374934yiv3797456984photo-title a, #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 div.ygrps-yiv-100374934yiv3797456984photo-title a:active, #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 div.ygrps-yiv-100374934yiv3797456984photo-title a:hover, #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 div.ygrps-yiv-100374934yiv3797456984photo-title a:visited { text-decoration:none;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 div#ygrps-yiv-100374934yiv3797456984ygrp-mlmsg #ygrps-yiv-100374934yiv3797456984ygrp-msg p a span.ygrps-yiv-100374934yiv3797456984yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 .ygrps-yiv-100374934yiv3797456984green { color:#628c2a;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 .ygrps-yiv-100374934yiv3797456984MsoNormal { margin:0 0 0 0;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 o { font-size:0;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984photos div { float:left;width:72px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984reco-category { font-size:77%;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984reco-desc { font-size:77%;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 .ygrps-yiv-100374934yiv3797456984replbq { margin:4px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mlmsg select, #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 input, #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mlmsg pre, #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 code { font:115% monospace;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-mlmsg #ygrps-yiv-100374934yiv3797456984logo { padding-bottom:10px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-msg p#ygrps-yiv-100374934yiv3797456984attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-reco #ygrps-yiv-100374934yiv3797456984reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-sponsor #ygrps-yiv-100374934yiv3797456984ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-sponsor #ygrps-yiv-100374934yiv3797456984ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-sponsor #ygrps-yiv-100374934yiv3797456984ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-text { font-family:Georgia;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-text tt { font-size:120%;} #ygrps-yiv-100374934 #ygrps-yiv-100374934yiv3797456984 #ygrps-yiv-100374934yiv3797456984ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-100374934 '
Posted: Mon Aug 05, 2019 1:41 pm
by Bart R.J. Decock
' Thanks Bob,
This was very usefull.
I guess I'll start cutting some metal.Have a nice day, Bart
On Wednesday, 31 July 2019, 07:09:07 CEST, Robert Etter robertetter@ymail.com [fairchildclub] wrote:
I had the same problem that you have.  Mine happened to be in a box with some engine parts that was stolen.  About $2K in new Warner parts and several boxes of used parts that only had, at most, a couple 100 hours.  I still had the wood blocks that clamped around the diagonal tube which was nice.  I fabricated the mounting plate and ended up using a 90 deg.  1" dia. (I think) ABS elbow as a replacement.  Cut the female side at 45 deg. angle.  Then cut about 1/4" off the female collar.   The hole that I cut in the mounting place was just a tick larger than the male side diameter.  After mounting the plate, I put the male side through the plate and put the collar in the back side with a couple drops of cement.  I didn't put it on tight so it would rotate easily.  All of those areas between the windshield frame that the wood blocks (covered them with upholstery fabric), packed in a thin strip of felt to seal it off, to force the air through the home made ABS vent.In case you haven't done it, be sure to drill a drain hole in the inboard rear corner of the wings air box,....to drain any water when it rains.  You will need someone with really small hands.  I think I used 1 3/4" scat duct between the wing duct and the windshield frame.  Used RTV sparingly on both ends, but not at the ON/OFF rod.   My control rod was really tight, may need some future work to free it up.  I may need a flexible coupler on the rod between the wing and cabin.  There is no chance of finding my original vents.  All of the parts were destroyed in a flood at the airport on the North side of St Louis many years ago.If you can't find the OE vents, this may help.Bob On ?Monday?, ?July? ?22?, ?2019? ?09?:?50?:?00? ?AM? ?PDT, 'Bart R.J.. Decock' c47fleetmaster@yahoo.co.uk [fairchildclub] wrote:
Hi,
Bart
#ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475 -- #ygrps-yiv-814028925yiv5802048475ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mkp #ygrps-yiv-814028925yiv5802048475hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mkp #ygrps-yiv-814028925yiv5802048475ads { margin-bottom:10px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mkp .ygrps-yiv-814028925yiv5802048475ad { padding:0 0;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mkp .ygrps-yiv-814028925yiv5802048475ad p { margin:0;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mkp .ygrps-yiv-814028925yiv5802048475ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-sponsor #ygrps-yiv-814028925yiv5802048475ygrp-lc { font-family:Arial;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-sponsor #ygrps-yiv-814028925yiv5802048475ygrp-lc #ygrps-yiv-814028925yiv5802048475hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-sponsor #ygrps-yiv-814028925yiv5802048475ygrp-lc .ygrps-yiv-814028925yiv5802048475ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475activity span { font-weight:700;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475activity span:first-child { text-transform:uppercase;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475activity span span { color:#ff7900;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475activity span .ygrps-yiv-814028925yiv5802048475underline { text-decoration:underline;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 .ygrps-yiv-814028925yiv5802048475attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 .ygrps-yiv-814028925yiv5802048475attach div a { text-decoration:none;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 .ygrps-yiv-814028925yiv5802048475attach img { border:none;padding-right:5px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 .ygrps-yiv-814028925yiv5802048475attach label { display:block;margin-bottom:5px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 .ygrps-yiv-814028925yiv5802048475attach label a { text-decoration:none;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 blockquote { margin:0 0 0 4px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 .ygrps-yiv-814028925yiv5802048475bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 .ygrps-yiv-814028925yiv5802048475bold a { text-decoration:none;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 dd.ygrps-yiv-814028925yiv5802048475last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 dd.ygrps-yiv-814028925yiv5802048475last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 dd.ygrps-yiv-814028925yiv5802048475last p span.ygrps-yiv-814028925yiv5802048475yshortcuts { margin-right:0;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 div.ygrps-yiv-814028925yiv5802048475attach-table div div a { text-decoration:none;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 div.ygrps-yiv-814028925yiv5802048475attach-table { width:400px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 div.ygrps-yiv-814028925yiv5802048475file-title a, #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 div.ygrps-yiv-814028925yiv5802048475file-title a:active, #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 div.ygrps-yiv-814028925yiv5802048475file-title a:hover, #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 div.ygrps-yiv-814028925yiv5802048475file-title a:visited { text-decoration:none;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 div.ygrps-yiv-814028925yiv5802048475photo-title a, #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 div.ygrps-yiv-814028925yiv5802048475photo-title a:active, #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 div.ygrps-yiv-814028925yiv5802048475photo-title a:hover, #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 div.ygrps-yiv-814028925yiv5802048475photo-title a:visited { text-decoration:none;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 div#ygrps-yiv-814028925yiv5802048475ygrp-mlmsg #ygrps-yiv-814028925yiv5802048475ygrp-msg p a span.ygrps-yiv-814028925yiv5802048475yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 .ygrps-yiv-814028925yiv5802048475green { color:#628c2a;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 .ygrps-yiv-814028925yiv5802048475MsoNormal { margin:0 0 0 0;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 o { font-size:0;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475photos div { float:left;width:72px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475reco-category { font-size:77%;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475reco-desc { font-size:77%;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 .ygrps-yiv-814028925yiv5802048475replbq { margin:4px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mlmsg select, #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 input, #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mlmsg pre, #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 code { font:115% monospace;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-mlmsg #ygrps-yiv-814028925yiv5802048475logo { padding-bottom:10px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-msg p#ygrps-yiv-814028925yiv5802048475attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-reco #ygrps-yiv-814028925yiv5802048475reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-sponsor #ygrps-yiv-814028925yiv5802048475ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-sponsor #ygrps-yiv-814028925yiv5802048475ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-sponsor #ygrps-yiv-814028925yiv5802048475ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-text { font-family:Georgia;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-text tt { font-size:120%;} #ygrps-yiv-814028925 #ygrps-yiv-814028925yiv5802048475 #ygrps-yiv-814028925yiv5802048475ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-814028925 '
Posted: Tue Aug 06, 2019 1:14 am
by robert Etter
' Send me a different address and I will try again to send you some photos.
On ?Monday?, ?August? ?5?, ?2019? ?12?:?50?:?42? ?PM? ?PDT, 'Bart R.J. Decock' c47fleetmaster@yahoo.co.uk [fairchildclub] wrote:
Thanks Bob,
I had the same problem that you have.  Mine happened to be in a box with some engine parts that was stolen.  About $2K in new Warner parts and several boxes of used parts that only had, at most, a couple 100 hours.  I still had the wood blocks that clamped around the diagonal tube which was nice.  I fabricated the mounting plate and ended up using a 90 deg.  1" dia. (I think) ABS elbow as a replacement.  Cut the female side at 45 deg. angle.  Then cut about 1/4" off the female collar.   The hole that I cut in the mounting place was just a tick larger than the male side diameter.  After mounting the plate, I put the male side through the plate and put the collar in the back side with a couple drops of cement.  I didn't put it on tight so it would rotate easily.  All of those areas between the windshield frame that the wood blocks (covered them with upholstery fabric), packed in a thin strip of felt to seal it off, to force the air through the home made ABS vent.In case you haven't done it, be sure to drill a drain hole in the inboard rear corner of the wings air box,....to drain any water when it rains.  You will need someone with really small hands.  I think I used 1 3/4" scat duct between the wing duct and the windshield frame.  Used RTV sparingly on both ends, but not at the ON/OFF rod.   My control rod was really tight, may need some future work to free it up.  I may need a flexible coupler on the rod between the wing and cabin.  There is no chance of finding my original vents.  All of the parts were destroyed in a flood at the airport on the North side of St Louis many years ago.If you can't find the OE vents, this may help.Bob On ?Monday?, ?July? ?22?, ?2019? ?09?:?50?:?00? ?AM? ?PDT, 'Bart R.J... Decock' c47fleetmaster@yahoo.co.uk [fairchildclub] wrote:
Hi,
Bart
#ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714 -- #ygrps-yiv-1393086187yiv0086276714ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mkp #ygrps-yiv-1393086187yiv0086276714hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mkp #ygrps-yiv-1393086187yiv0086276714ads { margin-bottom:10px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mkp .ygrps-yiv-1393086187yiv0086276714ad { padding:0 0;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mkp .ygrps-yiv-1393086187yiv0086276714ad p { margin:0;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mkp .ygrps-yiv-1393086187yiv0086276714ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-sponsor #ygrps-yiv-1393086187yiv0086276714ygrp-lc { font-family:Arial;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-sponsor #ygrps-yiv-1393086187yiv0086276714ygrp-lc #ygrps-yiv-1393086187yiv0086276714hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-sponsor #ygrps-yiv-1393086187yiv0086276714ygrp-lc .ygrps-yiv-1393086187yiv0086276714ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714activity span { font-weight:700;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714activity span span { color:#ff7900;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714activity span .ygrps-yiv-1393086187yiv0086276714underline { text-decoration:underline;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 .ygrps-yiv-1393086187yiv0086276714attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 .ygrps-yiv-1393086187yiv0086276714attach div a { text-decoration:none;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 .ygrps-yiv-1393086187yiv0086276714attach img { border:none;padding-right:5px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 .ygrps-yiv-1393086187yiv0086276714attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 .ygrps-yiv-1393086187yiv0086276714attach label a { text-decoration:none;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 .ygrps-yiv-1393086187yiv0086276714bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 .ygrps-yiv-1393086187yiv0086276714bold a { text-decoration:none;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 dd.ygrps-yiv-1393086187yiv0086276714last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 dd.ygrps-yiv-1393086187yiv0086276714last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 dd.ygrps-yiv-1393086187yiv0086276714last p span.ygrps-yiv-1393086187yiv0086276714yshortcuts { margin-right:0;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 div.ygrps-yiv-1393086187yiv0086276714attach-table div div a { text-decoration:none;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 div.ygrps-yiv-1393086187yiv0086276714attach-table { width:400px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 div.ygrps-yiv-1393086187yiv0086276714file-title a, #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 div.ygrps-yiv-1393086187yiv0086276714file-title a:active, #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 div.ygrps-yiv-1393086187yiv0086276714file-title a:hover, #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 div.ygrps-yiv-1393086187yiv0086276714file-title a:visited { text-decoration:none;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 div.ygrps-yiv-1393086187yiv0086276714photo-title a, #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 div.ygrps-yiv-1393086187yiv0086276714photo-title a:active, #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 div.ygrps-yiv-1393086187yiv0086276714photo-title a:hover, #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 div.ygrps-yiv-1393086187yiv0086276714photo-title a:visited { text-decoration:none;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 div#ygrps-yiv-1393086187yiv0086276714ygrp-mlmsg #ygrps-yiv-1393086187yiv0086276714ygrp-msg p a span.ygrps-yiv-1393086187yiv0086276714yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 .ygrps-yiv-1393086187yiv0086276714green { color:#628c2a;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 .ygrps-yiv-1393086187yiv0086276714MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 o { font-size:0;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714photos div { float:left;width:72px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714reco-category { font-size:77%;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714reco-desc { font-size:77%;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 .ygrps-yiv-1393086187yiv0086276714replbq { margin:4px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mlmsg select, #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 input, #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mlmsg pre, #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 code { font:115% monospace;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-mlmsg #ygrps-yiv-1393086187yiv0086276714logo { padding-bottom:10px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-msg p#ygrps-yiv-1393086187yiv0086276714attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-reco #ygrps-yiv-1393086187yiv0086276714reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-sponsor #ygrps-yiv-1393086187yiv0086276714ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-sponsor #ygrps-yiv-1393086187yiv0086276714ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-sponsor #ygrps-yiv-1393086187yiv0086276714ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-text { font-family:Georgia;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-text tt { font-size:120%;} #ygrps-yiv-1393086187 #ygrps-yiv-1393086187yiv0086276714 #ygrps-yiv-1393086187yiv0086276714ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1393086187 '
