Page 1 of 2
F24 oleo
Posted: Mon Jul 01, 2019 12:52 pm
by dc871f
What the best method of unscrewing the top cap?
Does the strut need to be compressed a little to remove the top cap, or can you just start removing it unloaded?
Thanks.'
Re: F24 oleo
Posted: Mon Jul 01, 2019 1:08 pm
by Francis Cox
'With a pin spanner/wrench - spring is at the bottom of the oleo.
On Mon, 1 Jul 2019 at 19:52,
Thanks.
Re: F24 oleo
Posted: Mon Jul 01, 2019 1:14 pm
by dc871f
'But it doesnt need to be compressed to relieve any tension from the spring to disassemble?
Thank you.'
Re: F24 oleo
Posted: Mon Jul 01, 2019 1:22 pm
by Francis Cox
'No because the weight of the aircraft is sitting on the spring
Frank
On Mon, 1 Jul 2019 at 20:18,
Thank you.
Re: F24 oleo
Posted: Mon Jul 01, 2019 1:46 pm
by dc871f
'Ok, thanks.
I guess I was thinking I would remove it from the airplane then disassemble.
But I guess loosening it with weight on it then removing will work as well.
Thanks'
Re: F24 oleo
Posted: Mon Jul 01, 2019 2:25 pm
by Bob Webster
' #ygrps-yiv-1549232172 {margin:0.7em;}#ygrps-yiv-1549232172 .ygrps-yiv-1549232172OECFntDef, #ygrps-yiv-1549232172 .ygrps-yiv-1549232172OECFntDef div {font-family:"Segoe UI", Tahoma, Verdana, Arial, Helvetica, sans-serif;font-size:14pt;} I changed mine some years ago. I raised the airplane by the engine mounts and removed the legs (one at a time) amd got some iron pipe to replace the legs with some drilling involved. The size of the 4130 tubing is in the maintenance manual. (Long gone) Then I put the old legs in a lathe and turned off the upper leg fittings. really just surface cuts and the old upper leg fittings popped right out. Welded the old upper leg fittings onto the new 4130. The lower leg leathers or whatever they were, were fine. Reassembled it all and it rode like a Caddilac. Hope this helped. Bob --- New Outlook Express and Windows Live Mail replacement - get it here:
https://www.oeclassic.com/ ----- Original Message ----- From: dc871f@yahoo.com [fairchildclub]
Reply-To: To: Sent: 7/1/2019 2:40:55 PM
Subject: [fairchildclub] Re: F24 oleo
Ok, thanks.
Virus-free.
www.avast.com '
Re: F24 oleo
Posted: Mon Jul 01, 2019 2:43 pm
by dc871f
'You lathed the cap? Seized?
What fluid did you use after rebuilding?'
Re: F24 oleo
Posted: Mon Jul 01, 2019 2:44 pm
by dc871f
'Ah, re-read your post.
Got it.
Thats pretty neat, I'm guessing when they were building these airplanes that just kept it simple.
I like it.'
Re: F24 oleo
Posted: Mon Jul 01, 2019 3:08 pm
by Guest
'#ygrps-yiv-237770894 {font-family:Geneva, Arial, Helvetica, sans-serif;font-size:9pt;background-color:#ffffff;color:black;}I should have mentioned that I raised it with a chain fall.
frankjcox44@gmail.com [fairchildclub]"
Sent: Jul 1, 2019 2:22 PM
fairchildclub@yahoogroups.com
Subject: Re: [fairchildclub] Re: F24 oleo
Frank
Thank you.
Re: F24 oleo
Posted: Mon Jul 01, 2019 3:21 pm
by dc871f
'What fluid did you use after rebuilding?
David'
