Propeller Reinstallation
Posted: Wed Mar 21, 2018 9:51 am
I sent my propeller to Sensenich for balancing and refinishing. When reinstalling, are there any suggestions/techniques to consider? I marked the prop, prop hub, prop flange, and spline so that the prop will be replaced in the same position before removal. When I removed the prop/hub there seemed to be no lubricant on the spline. Is this normal? I understand that the prop nut should be tightened to 150 man lbs on a 3 ft bar or 450ftlbs. Is there anything I'm missing? Thanks in advance.
Michael Drebo
832 691-0911
Magnolia, TX
Michael Drebo
832 691-0911
Magnolia, TX
