On Mon, 2/5/18, Terry Gardner
gtg15751@yahoo.com [fairchildclub]  wrote:
  Subject: Re: [fairchildclub] PT 19 Propeller Removal
fairchildclub@yahoogroups.com
  Date: Monday, February 5, 2018, 1:15 PM
        it is not just the snap ring! the hub may be the
  kind that does not use one . also the nut must have the
  groove as well as the hub for the snap ring. look on the hub
  for a tag " Warner and the number"one type uses
  the snap ring one doesn't[ I think the 79XX uses the
  snap; the 85..or 88.. doesn't]. I may have both for the
  warner that uses the long nut with the snap ring. If you
  have the short nut I do not have either. the nut without the
  groove may be used for either snap or no snap but for a snap
  ring both hub and nut must have the groove use the snap rig
  . the hub will also have a split front cone that is kept in
  place by the ring and the one that doesn't have the snap
  and groove do not use a front cone[talking about warner hubs
  only]. make sure to put a small amount of shell #5 great on
  the spline before replacing the prop and lightning.Thread
  lube ask also.
   I think fresno is out of the nuts and rings.
  On Sun, 2/4/18, Curt Kinchen
ptcurt@gmail.com
  [fairchildclub]
   Date: Sunday, February 4, 2018, 1:37 PM
         They used to be fairly common at prop
   shops, but I don't know how many are hanging
  about.
    Maybe check with Air Repair.  I put the hub AN spec
  in
   the group files, but don't recall if the snap ring
  is
   called out.
   On Feb 4, 2018 1:55 PM,
gdrebo@yahoo.com
   [fairchildclub]"  wrote:
         Curt,
   Thanks for the explanation..  It is
   starting to make sense to me.  Do you happen to have a
   source/AN # for snap ring?
   Michael Drebo832 691-0911
   #yiv2170142835 #yiv2170142835 --
     #yiv2170142835ygrp-mkp {
   border:1px solid #d8d8d8;font-family:Arial;margin:10px
   0;padding:0 10px;}
   #yiv2170142835 #yiv2170142835ygrp-mkp hr {
   border:1px solid #d8d8d8;}
   #yiv2170142835 #yiv2170142835ygrp-mkp #yiv2170142835hd {
   color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px
   0;}
   #yiv2170142835 #yiv2170142835ygrp-mkp #yiv2170142835ads
   margin-bottom:10px;}
   #yiv2170142835 #yiv2170142835ygrp-mkp .yiv2170142835ad {
   padding:0 0;}
   #yiv2170142835 #yiv2170142835ygrp-mkp .yiv2170142835ad p
   margin:0;}
   #yiv2170142835 #yiv2170142835ygrp-mkp .yiv2170142835ad a
   color:#0000ff;text-decoration:none;}
   #yiv2170142835 #yiv2170142835ygrp-sponsor
   #yiv2170142835ygrp-lc {
   font-family:Arial;}
   #yiv2170142835ygrp-lc #yiv2170142835hd {
   margin:10px
   0px;font-weight:700;font-size:78%;line-height:122%;}
   #yiv2170142835ygrp-lc .yiv2170142835ad {
   margin-bottom:10px;padding:0 0;}
   #yiv2170142835 #yiv2170142835actions {
   font-family:Verdana;font-size:11px;padding:10px 0;}
   #yiv2170142835 #yiv2170142835activity {
   background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
   #yiv2170142835 #yiv2170142835activity span {
   font-weight:700;}
   #yiv2170142835 #yiv2170142835activity span:first-child {
   text-transform:uppercase;}
   #yiv2170142835 #yiv2170142835activity span a {
   color:#5085b6;text-decoration:none;}
   #yiv2170142835 #yiv2170142835activity span span {
   color:#ff7900;}
   .yiv2170142835underline {
   text-decoration:underline;}
   #yiv2170142835 .yiv2170142835attach {
   clear:both;display:table;font-family:Arial;font-size:12px;padding:10px
   0;width:400px;}
   #yiv2170142835 .yiv2170142835attach div a {
   #yiv2170142835 .yiv2170142835attach img {
   border:none;padding-right:5px;}
   #yiv2170142835 .yiv2170142835attach label {
   display:block;margin-bottom:5px;}
   #yiv2170142835 .yiv2170142835attach label a {
   #yiv2170142835 blockquote {
   margin:0 0 0 4px;}
   #yiv2170142835 .yiv2170142835bold {
   font-family:Arial;font-size:13px;font-weight:700;}
   #yiv2170142835 .yiv2170142835bold a {
   #yiv2170142835 dd.yiv2170142835last p a {
   font-family:Verdana;font-weight:700;}
   #yiv2170142835 dd.yiv2170142835last p span {
   margin-right:10px;font-family:Verdana;font-weight:700;}
   span.yiv2170142835yshortcuts {
   margin-right:0;}
   #yiv2170142835 div.yiv2170142835attach-table div div a {
   #yiv2170142835 div.yiv2170142835attach-table {
   width:400px;}
   #yiv2170142835 div.yiv2170142835file-title a,
  #yiv2170142835
   div.yiv2170142835file-title a:active, #yiv2170142835
   div.yiv2170142835file-title a:hover, #yiv2170142835
   div.yiv2170142835file-title a:visited {
   #yiv2170142835 div.yiv2170142835photo-title a,
   #yiv2170142835 div.yiv2170142835photo-title a:active,
   #yiv2170142835 div.yiv2170142835photo-title a:hover,
   #yiv2170142835 div.yiv2170142835photo-title a:visited {
   #yiv2170142835 div#yiv2170142835ygrp-mlmsg
   #yiv2170142835ygrp-msg p a span.yiv2170142835yshortcuts
   font-family:Verdana;font-size:10px;font-weight:normal;}
   #yiv2170142835 .yiv2170142835green {
   color:#628c2a;}
   #yiv2170142835 .yiv2170142835MsoNormal {
   margin:0 0 0 0;}
   #yiv2170142835 o {
   font-size:0;}
   #yiv2170142835 #yiv2170142835photos div {
   float:left;width:72px;}
   #yiv2170142835 #yiv2170142835photos div div {
   border:1px solid
   #666666;min-height:62px;overflow:hidden;width:62px;}
   #yiv2170142835 #yiv2170142835photos div label {
   color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
   #yiv2170142835 #yiv2170142835reco-category {
   font-size:77%;}
   #yiv2170142835 #yiv2170142835reco-desc {
   font-size:77%;}
   #yiv2170142835 .yiv2170142835replbq {
   margin:4px;}
   #yiv2170142835 #yiv2170142835ygrp-actbar div a:first-child
   margin-right:2px;padding-right:5px;}
   #yiv2170142835 #yiv2170142835ygrp-mlmsg {
   font-size:13px;font-family:Arial, helvetica, clean,
   sans-serif;}
   #yiv2170142835 #yiv2170142835ygrp-mlmsg table {
   font-size:inherit;font:100%;}
   #yiv2170142835 #yiv2170142835ygrp-mlmsg select,
   #yiv2170142835 input, #yiv2170142835 textarea {
   font:99% Arial, Helvetica, clean, sans-serif;}
   #yiv2170142835 #yiv2170142835ygrp-mlmsg pre,
  #yiv2170142835
   code {
   font:115% monospace;}
   #yiv2170142835 #yiv2170142835ygrp-mlmsg * {
   line-height:1.22em;}
   #yiv2170142835 #yiv2170142835ygrp-mlmsg #yiv2170142835logo
   padding-bottom:10px;}
   #yiv2170142835 #yiv2170142835ygrp-msg p a {
   font-family:Verdana;}
   p#yiv2170142835attach-count span {
   color:#1E66AE;font-weight:700;}
   #yiv2170142835 #yiv2170142835ygrp-reco
   #yiv2170142835reco-head {
   color:#ff7900;font-weight:700;}
   #yiv2170142835 #yiv2170142835ygrp-reco {
   margin-bottom:20px;padding:0px;}
  #yiv2170142835ov
   li a {
   font-size:130%;text-decoration:none;}
  #yiv2170142835ov
   li {
   font-size:77%;list-style-type:square;padding:6px 0;}
  #yiv2170142835ov
   ul {
   margin:0;padding:0 0 0 8px;}
   #yiv2170142835 #yiv2170142835ygrp-text {
   font-family:Georgia;}
   #yiv2170142835 #yiv2170142835ygrp-text p {
   margin:0 0 1em 0;}
   #yiv2170142835 #yiv2170142835ygrp-text tt {
   font-size:120%;}
   #yiv2170142835 #yiv2170142835ygrp-vital ul li:last-child
   border-right:none !important;
   #yiv2170142835
  #yiv8406848842 #yiv8406848842 --
    #yiv8406848842ygrp-mkp {
  0;padding:0 10px;}
  #yiv8406848842 #yiv8406848842ygrp-mkp hr {
  #yiv8406848842 #yiv8406848842ygrp-mkp #yiv8406848842hd {
  0;}
  #yiv8406848842 #yiv8406848842ygrp-mkp #yiv8406848842ads {
  #yiv8406848842 #yiv8406848842ygrp-mkp .yiv8406848842ad {
  padding:0 0;}
  #yiv8406848842 #yiv8406848842ygrp-mkp .yiv8406848842ad p {
  margin:0;}
  #yiv8406848842 #yiv8406848842ygrp-mkp .yiv8406848842ad a {
  #yiv8406848842 #yiv8406848842ygrp-sponsor
  #yiv8406848842ygrp-lc {
  font-family:Arial;}
  #yiv8406848842ygrp-lc #yiv8406848842hd {
  margin:10px
  #yiv8406848842ygrp-lc .yiv8406848842ad {
  #yiv8406848842 #yiv8406848842actions {
  #yiv8406848842 #yiv8406848842activity {
  #yiv8406848842 #yiv8406848842activity span {
  font-weight:700;}
  #yiv8406848842 #yiv8406848842activity span:first-child {
  #yiv8406848842 #yiv8406848842activity span a {
  #yiv8406848842 #yiv8406848842activity span span {
  color:#ff7900;}
  .yiv8406848842underline {
  #yiv8406848842 .yiv8406848842attach {
  0;width:400px;}
  #yiv8406848842 .yiv8406848842attach div a {
  #yiv8406848842 .yiv8406848842attach img {
  #yiv8406848842 .yiv8406848842attach label {
  #yiv8406848842 .yiv8406848842attach label a {
  #yiv8406848842 blockquote {
  margin:0 0 0 4px;}
  #yiv8406848842 .yiv8406848842bold {
  #yiv8406848842 .yiv8406848842bold a {
  #yiv8406848842 dd.yiv8406848842last p a {
  #yiv8406848842 dd.yiv8406848842last p span {
  span.yiv8406848842yshortcuts {
  margin-right:0;}
  #yiv8406848842 div.yiv8406848842attach-table div div a {
  #yiv8406848842 div.yiv8406848842attach-table {
  width:400px;}
  #yiv8406848842 div.yiv8406848842file-title a, #yiv8406848842
  div.yiv8406848842file-title a:active, #yiv8406848842
  div.yiv8406848842file-title a:hover, #yiv8406848842
  div.yiv8406848842file-title a:visited {
  #yiv8406848842 div.yiv8406848842photo-title a,
  #yiv8406848842 div.yiv8406848842photo-title a:active,
  #yiv8406848842 div.yiv8406848842photo-title a:hover,
  #yiv8406848842 div.yiv8406848842photo-title a:visited {
  #yiv8406848842 div#yiv8406848842ygrp-mlmsg
  #yiv8406848842ygrp-msg p a span.yiv8406848842yshortcuts {
  #yiv8406848842 .yiv8406848842green {
  color:#628c2a;}
  #yiv8406848842 .yiv8406848842MsoNormal {
  margin:0 0 0 0;}
  #yiv8406848842 o {
  font-size:0;}
  #yiv8406848842 #yiv8406848842photos div {
  #yiv8406848842 #yiv8406848842photos div div {
  border:1px solid
  #yiv8406848842 #yiv8406848842photos div label {
  #yiv8406848842 #yiv8406848842reco-category {
  font-size:77%;}
  #yiv8406848842 #yiv8406848842reco-desc {
  font-size:77%;}
  #yiv8406848842 .yiv8406848842replbq {
  margin:4px;}
  #yiv8406848842 #yiv8406848842ygrp-actbar div a:first-child {
  #yiv8406848842 #yiv8406848842ygrp-mlmsg {
  sans-serif;}
  #yiv8406848842 #yiv8406848842ygrp-mlmsg table {
  #yiv8406848842 #yiv8406848842ygrp-mlmsg select,
  #yiv8406848842 input, #yiv8406848842 textarea {
  #yiv8406848842 #yiv8406848842ygrp-mlmsg pre, #yiv8406848842
  code {
  #yiv8406848842 #yiv8406848842ygrp-mlmsg * {
  #yiv8406848842 #yiv8406848842ygrp-mlmsg #yiv8406848842logo {
  #yiv8406848842 #yiv8406848842ygrp-msg p a {
  p#yiv8406848842attach-count span {
  #yiv8406848842 #yiv8406848842ygrp-reco
  #yiv8406848842reco-head {
  #yiv8406848842 #yiv8406848842ygrp-reco {
  #yiv8406848842 #yiv8406848842ygrp-sponsor #yiv8406848842ov
  li a {
  li {
  ul {
  #yiv8406848842 #yiv8406848842ygrp-text {
  #yiv8406848842 #yiv8406848842ygrp-text p {
  margin:0 0 1em 0;}
  #yiv8406848842 #yiv8406848842ygrp-text tt {
  font-size:120%;}
  #yiv8406848842 #yiv8406848842ygrp-vital ul li:last-child {
  #yiv8406848842
