PT main gear strut assembly
Posted: Sat Dec 16, 2017 7:07 pm
' It is time to replace my PTs main landing gear springs, as the strut is slowly getting lower when at rest. New springs (61107) were purchased years ago when someone was having a batch fabricated. But I’m having trouble removing the Victoprene Seal assembly (61141) from the top of the (61112) strut assembly. After removing the 4 AN510 screws the stop collar (61118) is still firmly in place. The top of the strut and collar is smooth – like it has been installed upside down or is actually a solid piece. The cup face must be facing into the strut but I can’t tell if that is the case. Perhaps there is a solid piece in place of the 61118 collar. Any info that can help me open up the strut to change the main gear spring would be appreciated. Also, is the actual Victoprene seal still available? Or what can be used in place of that?
