PT - Goodyear master cylinder O rings
Posted: Tue Aug 15, 2017 12:38 pm
'I'm trying to find the correct O ring for my Goodyear master cylinders
in a PT-19. Does anyone have dimensional specs for that O-ring?
I need a "Buna-N (nitrile) duro 70", O-ring for the Mil-h-5606 fluid
I'll be using. These are abundantly available online. My challenge is
determining the right size. The piston slot is 3/16" wide so I would
expect a 3/16" C.S. O-ring. It should stretch slightly over the piston
slot I believe, and be a couple or a few thousands larger than the bore
of the cylinder (1"). It should hold the piston in the center of the the
cylinder and not allow the piston to contact the cylinder. It should not
cause much resistance to the motion of the piston inside the cylinder.
I've tried a number of sizes in this range but none quite work so far.
Someone please correct me if I'm wrong about these parameters.
One person I know used a 1/8" C.S. x 1" O.D. O-ring from ACS,
MS-28775-210. He says it works and doesn't leak. I would expect it to be
too small in C.S and I.D., allowing the piston to rub against the
cylinder wall since it would not be tight in the slot due to a too small
C.S. and too small I.D., but would "flop" around in the extra space of
the 3/16" slot, and I would expect it to leak. Am I overthinking this?
I'd like to get this right - before filling the system with fluid if
possible!
Any ideas are much appreciated.
David
possible!
David
