Fairchild Fuselage lower bulkheads 3.5 thru 7.
Posted: Fri Mar 31, 2017 3:21 pm
by Seifert
'Does anyone on the Fairchild Club List have tracings of, or a set of, original wooden bulkheads for the 1937 F24G or H models.  There are no drawings available for the 41324 Bulkheads at stations 3-1/2 thru 7 and they are unique to only the F and G models.  What lower fuselage bulkheads I do have are in such bad shape I can't even use them for templates.If someone has the info I need I will make tracings, and make them available to the club.  I already have tracings of the upper bulkheads and will make them available as well.Please contact me if you can help.ThanksRich Seifert  714-356-6950or 1936f24h@gmail.com'
Re: Fairchild Fuselage lower bulkheads 3.5 thru 7.
Posted: Sat Apr 01, 2017 3:12 pm
by John Duncan
Hello Richard,
I do not have the drawings that you need.  But, if you travel to Colorado, you are welcome to inspect my 1937 F-24G, N-19173 and take any measurements, drawings, etc that you may need.
Kindest regards,
John Duncan
From: fairchildclub@yahoogroups.com on behalf of Richard Seifert 1936f24h@gmail.com [fairchildclub]
Sent: Friday, March 31, 2017 3:21 PM
To: Fairchild Club
Subject: [fairchildclub] Fairchild Fuselage lower bulkheads 3.5 thru 7.
Does anyone on the Fairchild Club List have tracings of, or a set of, original wooden bulkheads for the 1937 F24G or H models.  There are no drawings available for the 41324 Bulkheads at stations 3-1/2 thru 7 and they are unique to only the F and G models.  What lower fuselage bulkheads I do have are in such bad shape I can't even use them for templates. If someone has the info I need I will make tracings, and make them available to the club.  I already have tracings of the upper bulkheads and will make them available as well. Please contact me if you can help. Thanks Rich Seifert  714-356-6950 or 1936f24h@gmail.com
