Page 1 of 2
Warner 165 Gasket question
Posted: Wed Feb 22, 2017 8:22 am
by Joe Preston
' Does anyone know the number of the gasket that goes between the carb and the airbox for the Warner 165?  I do not see it listed in the parts manuals. The other question is where can I find one?   Joe   '
Re: Warner 165 Gasket question
Posted: Wed Feb 22, 2017 10:05 am
by JP
'I opted to reassemble without using one, if you do want to use one you will have to cut one out yourself. It is an easy thing to do
Sent from my iPad
On Feb 22, 2017, at 9:22 AM, Joe Preston Joe@Preston-Company.com [fairchildclub] wrote:
Posted: Wed Feb 22, 2017 10:35 am
by John Duncan
Hello Joe,
I think the number is 7156, and I may have one.  I will check and get back to you.
Regards,
John Duncan
Warner Engines
Great Lakes Aircraft
From: fairchildclub@yahoogroups.com on behalf of Joe Preston Joe@Preston-Company.com [fairchildclub]
Sent: Wednesday, February 22, 2017 7:22 AM
Subject: [fairchildclub] Warner 165 Gasket question
Posted: Wed Feb 22, 2017 10:39 am
by Joe Preston
' Thanks John, Where was the number listed? Just curious. It was not in either parts manuals.   -- Joe     From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Wednesday, February 22, 2017 11:36 AM
Subject: [fairchildclub] Re: Warner 165 Gasket question
Hello Joe,
Regards,
John Duncan
Warner Engines
Great Lakes Aircraft   From: fairchildclub@yahoogroups.com on behalf of Joe Preston Joe@Preston-Company.com [fairchildclub]
Subject: [fairchildclub] Warner 165 Gasket question     Does anyone know the number of the gasket that goes between the carb and the airbox for the Warner 165?  I do not see it listed in the parts manuals. The other question is where can I find one?   Joe   '
Posted: Wed Feb 22, 2017 10:46 am
by John Duncan
It is listed in the complete engine drawing located at the end of the Pilots Handbook......very small print and difficult to read.  This is the gasket used between the carburetor and induction housing.  If you need the gasket used on the intake side of the carb, it perhaps may be found in the Fairchild manual.
Regards,
JD
Sent: Wednesday, February 22, 2017 9:39 AM
Subject: [fairchildclub] RE: Warner 165 Gasket question
Hello Joe,
Regards,
John Duncan
Warner Engines
Posted: Wed Feb 22, 2017 10:56 am
by Joe Preston
' Yes, I need the one that attaches to the bottom of the carb.     -- Joe   From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Wednesday, February 22, 2017 11:44 AM
Regards,
JD   From: fairchildclub@yahoogroups.com on behalf of Joe Preston Joe@Preston-Company.com [fairchildclub]
Subject: [fairchildclub] RE: Warner 165 Gasket question     Thanks John, Where was the number listed? Just curious. It was not in either parts manuals.   -- Joe     From: fairchildclub@yahoogroups.com [fairchildclub@yahoogroups.com]
Hello Joe,
Regards,
John Duncan
Warner Engines
Posted: Wed Feb 22, 2017 10:14 pm
by ccmueller001
'The 2nd edition 165 parts catalog (1942  edition) I have shows 7156 as the gasket number. The price list that is stuck into the catalog (undated) has a price of .10
The price list also shows "Carburetor SS50-50A" on the same line.
The catalog cover shows that it is from: Paul Daily Air Goods, 1154 Halm Blvd., San Antonio. Texas 78216
I didn't think zip codes were introduced until the 60s, so that a bit of a puzzle.'
Posted: Thu Feb 23, 2017 5:40 am
by Joe Preston
I think that is the one that goes on the top of the carb. I need the one that goes on the bottom. It goes between the bottom of the carb and the heat control valve/airbox.
Joe
Sent from my iPad Mini
Posted: Thu Feb 23, 2017 11:23 pm
by Mueller, Charles
'My book doesn’t show the gasket for the inlet side of the carb.
They do show the heat control valve, but no gasket shown there either.
Is your Warner on a Great Lakes? I was trying to buy a Warner powered GL from the San Diego Air & Space Museum many years ago. They took so long to respond that I found another one. The day after I got that one home they accepted my offer!
Probably just as well.
Charles'
Posted: Fri Feb 24, 2017 7:45 am
by Joe Preston
Yes, it is a 1930 Great Lakes. I bought one of the new dishpans and am fitting the cowl around it.
Which airplane do you now have?
Joe
Sent: Friday, February 24, 2017 12:24 AM
Charles
