PT-19 brakes
Posted: Tue Nov 22, 2016 3:20 pm
'I need to replace brake lines due to corrosion and leaks in the lines.
Using AN fittings where possible seems like a good idea. I see the
inverted flare fitting at the master cylinder has an oddball thread at
the master cylinder. Not a pipe thread but looks like a straight thread,
so it seems unlikely I can replace that one with AN.
Questions:
1) is the inverted flare used on these brakes a 37 deg flare like AN?
(or 45?) Can I use my 37 deg AN flare tools?
2) Any suggestions for me? Is this a good idea or should I stay with the
inverted flare?
Thanks for any help.
David McCord
Questions:
inverted flare?
David McCord
