Push Pull Cables
Posted: Sat Aug 20, 2016 8:23 am
by Fritz
'On a PT-19 or PT-26, I need the Carb Heat Push Pull cable. Have we found someone who makes these, or is there a kind sole out there who has a good one????  Fritz MehrerSan Diego  '
Re: Push Pull Cables
Posted: Sat Aug 20, 2016 4:11 pm
by Buell Powell
'  Fritz,         You might try McFarlane Aviation (mcfarlaneaviation.com-1-866-920-2741) about making one .Not sure about all cables but at least for throttle cables they can furnish a drawing for you to fill in the dimensions and it can be used as an owner produced part. You can also send the original cable just to be sure. The cables they build are very well made.
Posted: Sat Aug 20, 2016 4:48 pm
by Fritz
'Ok, will give them a try.  This cable is, of course, is the DUAL cable for the carb heat that has “pulls” in both cockpits.Fritz  From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Saturday, August 20, 2016 3:12 PM
To: FAIRCHILD CLUB
Subject: Re: [fairchildclub] Push Pull Cables
On Aug 20, 2016, at 9:19 AM, 'Fritz' avdflyr@cox.net [fairchildclub] wrote:    On a PT-19 or PT-26, I need the Carb Heat Push Pull cable. Have we found someone who makes these, or is there a kind sole out there who has a good one???? Fritz MehrerSan Diego
