'Thanks Jamie.. In looking these over I see what they were trying to do
with the excess oil.. The reduction in clearance on bearings is mentioned
as a possible problem..
A customer wants to re-use pistons that have this modification done. I
line bore main bearings to .002 for each main.. I guess I could increase
clearance but by how much..
Not sure I want to mess with this...
Many thanks Jamie, I appreciate you help..
John
jamietreat@q.com [fairchildclub]
Sent: Friday, July 22, 2016 12:04 PM
fairchildclub@yahoogroups.com
Cc:
johnee35@att.net
Subject: RE: [fairchildclub] Monasco modification for Ranger Engine
John,
Are you talking about the Piston oil skirt modification? If you are, it is
similar to the Warner.
I have attached 8 docs that cover the Ranger mods.
All are on the CD/DVD under Vol 9, Eng & Accesory Manuals, Ranger 6-440C.
Hope this helps.
JST
Fairchild Club DVD Editor
IAC 5, Chapter President
http://iac5.org
Kelly Airpark (CO15)
http://www.kellyairpark.org
Hm 303-648-0130
Cell 303-304-7937
Quote of the Month: The emergencies you train for almost never happen. It's
the one you can't train for that kills you. - Ernest K. Gann, advice from
the 'old pelican'
Sent: Friday, July 22, 2016 10:51 AM
Subject: [fairchildclub] Monasco modification for Ranger Engine
Good Morning to all..
I would like a copy of the Menasco modification used on Ranger Engines..
I've looked on the internet and can't find.. It's probably there but I gave
up looking..
Thanks, I appreciate... John
Posted by: "Jamie Treat"
Yahoo Groups Links'
