Prop Hub spacing problem
Posted: Fri May 27, 2016 10:05 pm
'Dear List:
I put the prop on the Ranger of my '19 yesterday, and when torqued down
I'm about 1/8" or approximately a turn on the nut shy to be able to put
the 3/16" security pin in the hole thru the nut and the hub. Do I need
to turn down the spacer by that much? or is there something else I'm
overlooking?
Thanks for any help,
David'
overlooking?
David'
