F24W cowl
Posted: Sun May 22, 2016 6:25 am
by gtg15751
'#ygrps-yiv-786094440 {font-family:"Calibri", "Slate Pro", sans-serif, "sans-serif";color:#262626;} How much forward & aft movement should there be of the cowling?Sent from my BlackBerry 10 smartphone.'
Re: F24W cowl
Posted: Sun May 22, 2016 9:32 am
by robert Etter
'I can't remember who told me, but for sure you don't want the cowl of a 24W to be tight to the mount.  Especially when cold.  The cowl will need to have some movement for and aft even when the motor is warmed up.   There is multiple stops on the cowl mounts that will stop the cowl from moving too far forward.  I was told, as you can believe, the motor will grow in diameter as the overall temperature of the motor climbs.   If it is too tight, you will start to see cracks in the cowl around the front opening.There is two things you can do to fix the cracks.  Heli Arc the crack or wrap aluminum around the opening in the area of the crack and rivet it.  This should reinforce the crack area.  The information about how to do it is out there in the world.To answer your question, go fly around the patch once, land and shut the motor down.  Hop out and check the tightness of the cowl to the mounts.  If it doesn't move at all, it is too tight.After 43 years of down time, I will do much the same thing to my bird. Bob
On Sunday, May 22, 2016 5:25 AM, "gtg15751@yahoo.com [fairchildclub]" wrote:
  How much forward & aft movement should there be of the cowling?Sent from my BlackBerry 10 smartphone. #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208 -- #ygrps-yiv-1857622705yiv9679069208ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mkp #ygrps-yiv-1857622705yiv9679069208hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mkp #ygrps-yiv-1857622705yiv9679069208ads { margin-bottom:10px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mkp .ygrps-yiv-1857622705yiv9679069208ad { padding:0 0;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mkp .ygrps-yiv-1857622705yiv9679069208ad p { margin:0;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mkp .ygrps-yiv-1857622705yiv9679069208ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-sponsor #ygrps-yiv-1857622705yiv9679069208ygrp-lc { font-family:Arial;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-sponsor #ygrps-yiv-1857622705yiv9679069208ygrp-lc #ygrps-yiv-1857622705yiv9679069208hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-sponsor #ygrps-yiv-1857622705yiv9679069208ygrp-lc .ygrps-yiv-1857622705yiv9679069208ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208activity span { font-weight:700;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208activity span span { color:#ff7900;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208activity span .ygrps-yiv-1857622705yiv9679069208underline { text-decoration:underline;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 .ygrps-yiv-1857622705yiv9679069208attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 .ygrps-yiv-1857622705yiv9679069208attach div a { text-decoration:none;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 .ygrps-yiv-1857622705yiv9679069208attach img { border:none;padding-right:5px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 .ygrps-yiv-1857622705yiv9679069208attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 .ygrps-yiv-1857622705yiv9679069208attach label a { text-decoration:none;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 .ygrps-yiv-1857622705yiv9679069208bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 .ygrps-yiv-1857622705yiv9679069208bold a { text-decoration:none;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 dd.ygrps-yiv-1857622705yiv9679069208last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 dd.ygrps-yiv-1857622705yiv9679069208last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 dd.ygrps-yiv-1857622705yiv9679069208last p span.ygrps-yiv-1857622705yiv9679069208yshortcuts { margin-right:0;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 div.ygrps-yiv-1857622705yiv9679069208attach-table div div a { text-decoration:none;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 div.ygrps-yiv-1857622705yiv9679069208attach-table { width:400px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 div.ygrps-yiv-1857622705yiv9679069208file-title a, #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 div.ygrps-yiv-1857622705yiv9679069208file-title a:active, #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 div.ygrps-yiv-1857622705yiv9679069208file-title a:hover, #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 div.ygrps-yiv-1857622705yiv9679069208file-title a:visited { text-decoration:none;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 div.ygrps-yiv-1857622705yiv9679069208photo-title a, #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 div.ygrps-yiv-1857622705yiv9679069208photo-title a:active, #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 div.ygrps-yiv-1857622705yiv9679069208photo-title a:hover, #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 div.ygrps-yiv-1857622705yiv9679069208photo-title a:visited { text-decoration:none;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 div#ygrps-yiv-1857622705yiv9679069208ygrp-mlmsg #ygrps-yiv-1857622705yiv9679069208ygrp-msg p a span.ygrps-yiv-1857622705yiv9679069208yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 .ygrps-yiv-1857622705yiv9679069208green { color:#628c2a;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 .ygrps-yiv-1857622705yiv9679069208MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 o { font-size:0;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208photos div { float:left;width:72px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208reco-category { font-size:77%;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208reco-desc { font-size:77%;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 .ygrps-yiv-1857622705yiv9679069208replbq { margin:4px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mlmsg select, #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 input, #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mlmsg pre, #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 code { font:115% monospace;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-mlmsg #ygrps-yiv-1857622705yiv9679069208logo { padding-bottom:10px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-msg p#ygrps-yiv-1857622705yiv9679069208attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-reco #ygrps-yiv-1857622705yiv9679069208reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-sponsor #ygrps-yiv-1857622705yiv9679069208ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-sponsor #ygrps-yiv-1857622705yiv9679069208ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-sponsor #ygrps-yiv-1857622705yiv9679069208ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-text { font-family:Georgia;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-text tt { font-size:120%;} #ygrps-yiv-1857622705 #ygrps-yiv-1857622705yiv9679069208 #ygrps-yiv-1857622705yiv9679069208ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1857622705
Re: F24W cowl
Posted: Sun May 22, 2016 10:01 am
by gtg15751
'Thanks
Sent from my BlackBerry 10 smartphone. From: Robert Etter robertetter@ymail.com [fairchildclub]Sent: Sunday, May 22, 2016 10:32To: fairchildclub@yahoogroups.comReply To: fairchildclub@yahoogroups.comSubject: Re: [fairchildclub] F24W cowl
