'The Kit for the master cylinder at NAPA is 7 47730 08109 0. Bleeder screw is 6848. Copper washer 1246. I took that information from an old sales receipt. You may go to NAPA on line and find the dimensions. A short section of solid rubber vaccuum line works good for the nozzle packing.If you can find the information, there was 2 versions of the Hayes wheel assembles. One had the "lining retracting clips" and the other didn't. I have examples of both. The second version used what appeared to be Goodyear Plyobond (maybe spelled wrong) rubber cement to glue the brake blocks to the expander tube and didn't use clips. There wasn't slots for the clips.I can get anyone the numbers, if you want.Bob
On Wednesday, May 4, 2016 10:39 AM, "james chybicki
rampratone@yahoo.com [fairchildclub]" wrote:
any descriptions or reference numbers you can share?
avdflyr@cox.net [fairchildclub]"
Sent: Wednesday, May 4, 2016 10:11 AM
Subject: RE: [fairchildclub] Hayes Brake Parts
The copper gaskets for the banjo fitting are available in any quantity from Amazon. I just bought about 30, just for spares. You will need to know the right size in metric.
Sent: Wednesday, May 04, 2016 6:37 AM
To: yahoogroups
Subject: [fairchildclub] Hayes Brake Parts
Hi AllI know over the years I have seen emails back and forth about Hayes Brake parts for the F24 and PT airplanes.I would like to know if anyone has current Hayes or NAPA part numbers for the Bleeder Screw, "Banjo Fitting" and all the gaskets and seals associated with the Hayes brake system.I have brake pucks and springs and quite a few frames. but all the fitting and seals are non airworthy. for reference:UC-61 Illustrated parts manual AN01-115CA-4 Figure 30 items 3 through 16PT Illustrated parts manual AN01-115GA-4 Figure 35 items 3 through 20 With this information, I will compile an up to date list for the club to use. thanks JIM ChybickiMidwest Aeronautiques LLCUC-61K USAAF# 43-14964 / RAF # HB690RampRatOne-at-yahoo-dot-com
#ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362 -- #ygrps-yiv-975644578yiv9932905362ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mkp #ygrps-yiv-975644578yiv9932905362hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mkp #ygrps-yiv-975644578yiv9932905362ads { margin-bottom:10px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mkp .ygrps-yiv-975644578yiv9932905362ad { padding:0 0;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mkp .ygrps-yiv-975644578yiv9932905362ad p { margin:0;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mkp .ygrps-yiv-975644578yiv9932905362ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-sponsor #ygrps-yiv-975644578yiv9932905362ygrp-lc { font-family:Arial;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-sponsor #ygrps-yiv-975644578yiv9932905362ygrp-lc #ygrps-yiv-975644578yiv9932905362hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-sponsor #ygrps-yiv-975644578yiv9932905362ygrp-lc .ygrps-yiv-975644578yiv9932905362ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362activity span { font-weight:700;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362activity span:first-child { text-transform:uppercase;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362activity span span { color:#ff7900;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362activity span .ygrps-yiv-975644578yiv9932905362underline { text-decoration:underline;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 .ygrps-yiv-975644578yiv9932905362attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 .ygrps-yiv-975644578yiv9932905362attach div a { text-decoration:none;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 .ygrps-yiv-975644578yiv9932905362attach img { border:none;padding-right:5px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 .ygrps-yiv-975644578yiv9932905362attach label { display:block;margin-bottom:5px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 .ygrps-yiv-975644578yiv9932905362attach label a { text-decoration:none;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 blockquote { margin:0 0 0 4px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 .ygrps-yiv-975644578yiv9932905362bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 .ygrps-yiv-975644578yiv9932905362bold a { text-decoration:none;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 dd.ygrps-yiv-975644578yiv9932905362last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 dd.ygrps-yiv-975644578yiv9932905362last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 dd.ygrps-yiv-975644578yiv9932905362last p span.ygrps-yiv-975644578yiv9932905362yshortcuts { margin-right:0;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 div.ygrps-yiv-975644578yiv9932905362attach-table div div a { text-decoration:none;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 div.ygrps-yiv-975644578yiv9932905362attach-table { width:400px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 div.ygrps-yiv-975644578yiv9932905362file-title a, #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 div.ygrps-yiv-975644578yiv9932905362file-title a:active, #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 div.ygrps-yiv-975644578yiv9932905362file-title a:hover, #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 div.ygrps-yiv-975644578yiv9932905362file-title a:visited { text-decoration:none;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 div.ygrps-yiv-975644578yiv9932905362photo-title a, #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 div.ygrps-yiv-975644578yiv9932905362photo-title a:active, #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 div.ygrps-yiv-975644578yiv9932905362photo-title a:hover, #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 div.ygrps-yiv-975644578yiv9932905362photo-title a:visited { text-decoration:none;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 div#ygrps-yiv-975644578yiv9932905362ygrp-mlmsg #ygrps-yiv-975644578yiv9932905362ygrp-msg p a span.ygrps-yiv-975644578yiv9932905362yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 .ygrps-yiv-975644578yiv9932905362green { color:#628c2a;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 .ygrps-yiv-975644578yiv9932905362MsoNormal { margin:0 0 0 0;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 o { font-size:0;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362photos div { float:left;width:72px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362reco-category { font-size:77%;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362reco-desc { font-size:77%;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 .ygrps-yiv-975644578yiv9932905362replbq { margin:4px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mlmsg select, #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 input, #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mlmsg pre, #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 code { font:115% monospace;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-mlmsg #ygrps-yiv-975644578yiv9932905362logo { padding-bottom:10px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-msg p#ygrps-yiv-975644578yiv9932905362attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-reco #ygrps-yiv-975644578yiv9932905362reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-sponsor #ygrps-yiv-975644578yiv9932905362ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-sponsor #ygrps-yiv-975644578yiv9932905362ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-sponsor #ygrps-yiv-975644578yiv9932905362ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-text { font-family:Georgia;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-text tt { font-size:120%;} #ygrps-yiv-975644578 #ygrps-yiv-975644578yiv9932905362 #ygrps-yiv-975644578yiv9932905362ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-975644578
