'Lord calls the bushings mounts. So i do mean the bushings. So that we are clear i need the rubberized bushing that fits between the engine mount and the frame. It will look like a round piece of rubber with a metal tube going thru it. The bushing slips into a round tube at the end of each leg of the engine mount then a bolt goes thru the frame mount, thru the bushing and thru the frame mount once again. I dont know how to be more clear. What i need are the dimensions of the bushing. The length, the outside diameter, the inside diameter, etc
Thank you,Mike
Sent from my iPad
On Apr 11, 2016, at 08:15, 'Jamie Treat'
jamietreat@q.com [fairchildclub] wrote:
Mike, See other email. By mounts, you me bushings. He is not making mounts. Apples and oranges!!! Give me a call. 303-304-7937. JST
EFrom:
Subject: Re: [fairchildclub] Price for new Warner motor mounts. Like i said, all i need are the physical dimensions of the mounts he is making for the warners. Once i know that i can see if they are the same as the stc mount dimensions. Im not mounting a jake on a waco, it is mounting to a Fairchild 24w and the lord mounts the stc calls for are no longer made. Surely someone has take a set of calipers and measured them. Thanks,Mike
Sent from my iPad
On Apr 10, 2016, at 18:30, 'Jamie Treat'
jamietreat@q.com [fairchildclub] wrote: Don’t know the setup. Need to follow the STC. Depends on the mount setup. The Jake setup on the Waco’s utilize bushings that are similar to Cont A-65/O-200 type. Just many of them for support. The Owl mount uses something very similar also. Much cheaper than the Warner bushings. JST
Sent: Sunday, April 10, 2016 4:25 PM
Subject: Re: [fairchildclub] Price for new Warner motor mounts. Jamie, If you know the 'set up' for the Jacobs 'set up' why don't you pass the information on to Mike Thomas instead of just telling him 'it's different'. Any information is better than none. Knowledge is one thing a person give away (share) and it doesn't cost him anything. On Sunday, April 10, 2016 5:54 PM, "Jamie Treat
jamietreat@q.com [fairchildclub]" wrote: Nope. Totally diff set up Sent via the Samsung Galaxy S® 4 mini ™, an AT&T 4G LTE smartphone -------- Original message --------From: "Michael Thomas
michael_thomas8@yahoo.com [fairchildclub]" Date:04/10/2016 2:15 PM (GMT-07:00) To:
fairchildclub@yahoogroups.com Cc: Subject: Re: [fairchildclub] Price for new Warner motor mounts. I have a 1940 24W but the Warner engine is not with it and instead I have an STC for a Jacobs 755 along with a three jake engines. My question is whether the warner mounts will work with the jake. Do you happen to know the dimentions of the mount? Length, girth, id of metal bushing? I suspicion that they will be the same as the stc drawing because in the end they still have to mount to the aircraft frame but before i order them i need to be certain. Thanks,Mike Thomas
Sent from my iPad
On Apr 10, 2016, at 11:27,
hotfoot49@hotmail.com [fairchildclub] wrote: I forgot to put the pricce in my last post for the Warner mounts. Manfred has $87.50 each in his information to me. Keep 'em flying! Mike KellyFairhcild Club
