Push Pull Tube
Posted: Mon Mar 07, 2016 12:43 am
by Fritz
'Gentlemen,I need the push-pull tube that goes between the rudder and the tailwheel post. This tube is spring loaded and is about 13 inches long. I’m in San Diego. Fritz Mehrer '
Re: Push Pull Tube
Posted: Mon Mar 07, 2016 12:02 pm
by Fritz
'Push pull is for a PT 19 or 26
Sent: Sunday, March 06, 2016 10:43 PM
Subject: [fairchildclub] Push Pull Tube
Gentlemen,I need the push-pull tube that goes between the rudder and the tailwheel post. This tube is spring loaded and is about 13 inches long.I’m in San Diego. Fritz Mehrer
Re: Push Pull Tube
Posted: Wed Mar 09, 2016 7:52 pm
by cagog
'Fritz,Do you have one with worn rod ends or just not at all. Mine had worn out rod ends. If you just need rod ends I can help. Both are standard bearings (RE4H6) that get modified. One is drilled and threaded, the other has theO/D reduced. I am doing that machine work right now tomy new bearings. Ryan'
Re: Push Pull Tube
Posted: Wed Mar 09, 2016 8:56 pm
by Fritz
'Ryan,Thank you so much for the response… I need the complete assembly… Fritz
Sent: Wednesday, March 09, 2016 5:52 PM
Subject: RE: [fairchildclub] Push Pull Tube
