' would not retract when turned off...anyone had this happen or have any ideas?? Thanks, Tony Your center position on the switch is off, and down position will retract. To me, if you can't turn it off, either in the center position or won't retract, the switch is hung-up in the extend/light on position. If you feel little or no resistance or feel a slight clunk when you move the toggle; it is broken internally. If some one were to place a jumper across contacts to force to retract, not good. Maximum smoke may be the result. Dropping the lamp and disconnecting the power input cable is an option. The outer shell of the connector is Ground. One pin is for extend, and the other is for retract. Oops, I am referring is a ST-1220. If you have a ST-250, and it is Grimes, I would suspect they are electrically the same. If you are checking the power at the connector and you get nervous, put in the smallest amp fuse in the circuit for the lamp that you can find. It makes a much smaller spark. My ST-1220 is fused at 25 amps.Another thought, open the J-box above the left rear window. There is five terminals. "L" to "G" is for voltage to extend and operate the light. "M" to "G" is for lamp retract. Bob
On Monday, February 22, 2016 10:11 AM, "tdrood
tdrood@yahoo.com [fairchildclub]" wrote:
I would definitely check power at the (out of the) switch before I took the light out of the wing. I don't have the wiring diagram in front of me, but if someone would send me the diagram (or a sketch of the circuit) it should be pretty easy to isolate.
T
Sent from my Verizon Wireless 4G LTE smartphone-------- Original message --------From: "Tonyanger
tonyanger@yahoo.com [fairchildclub]" Date: 2/22/2016 10:27 AM (GMT-06:00) To:
fairchildclub@yahoogroups.com Subject: Re: [fairchildclub] landing light
That's what I was thinking I haven't found anything yet I'm getting ready to take the light out of the wing which is kind of a jerk I was just hoping maybe somebody had had this happen before and trying to see if there was something nominal or rare
Sent from my Sprint Samsung Galaxy S® 6.-------- Original message --------From: "tdrood
tdrood@yahoo.com [fairchildclub]" Date: 2/22/2016 7:46 AM (GMT-07:00) To: "Tonyanger
tonyanger@yahoo.com [fairchildclub]" Subject: Re: [fairchildclub] landing light
Could be a limit switch or a broken wire depending upon how the circuit is wired....
tonyanger@yahoo.com [fairchildclub]" Date: 2/22/2016 8:39 AM (GMT-06:00) To:
Yes it is a three position switch so I'm guessing the retract contact is not working I will research that today
Sent from my Sprint Samsung Galaxy S® 6.-------- Original message --------From: "Pattee News
patteenews@gmail.com [fairchildclub]" Date: 2/22/2016 7:31 AM (GMT-07:00) To:
My landing light switch has three positions. 1. Extend - On2. Off (Center)3. RetractAfter use, I switch off, let cool, then before shutdown, I retract and then center switch. Yours too?David
On Feb 22, 2016, at 08:09,
tonyanger@yahoo.com [fairchildclub] wrote:
Hi gang...I was testing all the lights and my landing light came out and worked, but would not retract when turned off...anyone had this happen or have any ideas?? Thanks, Tony
#ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938 -- #ygrps-yiv-1761969242yiv9384500938ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mkp #ygrps-yiv-1761969242yiv9384500938hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mkp #ygrps-yiv-1761969242yiv9384500938ads { margin-bottom:10px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mkp .ygrps-yiv-1761969242yiv9384500938ad { padding:0 0;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mkp .ygrps-yiv-1761969242yiv9384500938ad p { margin:0;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mkp .ygrps-yiv-1761969242yiv9384500938ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-sponsor #ygrps-yiv-1761969242yiv9384500938ygrp-lc { font-family:Arial;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-sponsor #ygrps-yiv-1761969242yiv9384500938ygrp-lc #ygrps-yiv-1761969242yiv9384500938hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-sponsor #ygrps-yiv-1761969242yiv9384500938ygrp-lc .ygrps-yiv-1761969242yiv9384500938ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938activity span { font-weight:700;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938activity span span { color:#ff7900;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938activity span .ygrps-yiv-1761969242yiv9384500938underline { text-decoration:underline;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 .ygrps-yiv-1761969242yiv9384500938attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 .ygrps-yiv-1761969242yiv9384500938attach div a { text-decoration:none;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 .ygrps-yiv-1761969242yiv9384500938attach img { border:none;padding-right:5px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 .ygrps-yiv-1761969242yiv9384500938attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 .ygrps-yiv-1761969242yiv9384500938attach label a { text-decoration:none;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 .ygrps-yiv-1761969242yiv9384500938bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 .ygrps-yiv-1761969242yiv9384500938bold a { text-decoration:none;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 dd.ygrps-yiv-1761969242yiv9384500938last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 dd.ygrps-yiv-1761969242yiv9384500938last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 dd.ygrps-yiv-1761969242yiv9384500938last p span.ygrps-yiv-1761969242yiv9384500938yshortcuts { margin-right:0;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 div.ygrps-yiv-1761969242yiv9384500938attach-table div div a { text-decoration:none;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 div.ygrps-yiv-1761969242yiv9384500938attach-table { width:400px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 div.ygrps-yiv-1761969242yiv9384500938file-title a, #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 div.ygrps-yiv-1761969242yiv9384500938file-title a:active, #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 div.ygrps-yiv-1761969242yiv9384500938file-title a:hover, #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 div.ygrps-yiv-1761969242yiv9384500938file-title a:visited { text-decoration:none;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 div.ygrps-yiv-1761969242yiv9384500938photo-title a, #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 div.ygrps-yiv-1761969242yiv9384500938photo-title a:active, #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 div.ygrps-yiv-1761969242yiv9384500938photo-title a:hover, #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 div.ygrps-yiv-1761969242yiv9384500938photo-title a:visited { text-decoration:none;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 div#ygrps-yiv-1761969242yiv9384500938ygrp-mlmsg #ygrps-yiv-1761969242yiv9384500938ygrp-msg p a span.ygrps-yiv-1761969242yiv9384500938yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 .ygrps-yiv-1761969242yiv9384500938green { color:#628c2a;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 .ygrps-yiv-1761969242yiv9384500938MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 o { font-size:0;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938photos div { float:left;width:72px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938reco-category { font-size:77%;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938reco-desc { font-size:77%;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 .ygrps-yiv-1761969242yiv9384500938replbq { margin:4px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mlmsg select, #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 input, #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mlmsg pre, #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 code { font:115% monospace;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-mlmsg #ygrps-yiv-1761969242yiv9384500938logo { padding-bottom:10px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-msg p#ygrps-yiv-1761969242yiv9384500938attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-reco #ygrps-yiv-1761969242yiv9384500938reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-sponsor #ygrps-yiv-1761969242yiv9384500938ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-sponsor #ygrps-yiv-1761969242yiv9384500938ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-sponsor #ygrps-yiv-1761969242yiv9384500938ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-text { font-family:Georgia;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-text tt { font-size:120%;} #ygrps-yiv-1761969242 #ygrps-yiv-1761969242yiv9384500938 #ygrps-yiv-1761969242yiv9384500938ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1761969242
