Re: F24 (UC61K) Right rudder pedal release springs: spring manufactu
Posted: Mon Sep 14, 2015 8:17 am
by Hans Friedebach
'To all:
Springs Inc , Dan Rademacher, Forest Lake, Minnesota has the capability to make what you need. It would probably pay to have a small quantity made at the same time and make them available to other F24 owners. The cost is the set up primarily.
Hans Friedebach
Sent: Monday, September 14, 2015 9:45 AM
Subject: Re: [fairchildclub] F24 (UC61K) Right rudder pedal release springs
Frank.
Many spring manufactures will custom make springs to your specifications and/or replicate an existing spring.
Choose a spring manufacturer and make an inquiry. If you have the spring drawing/specifications or a sample spring to replicate tell them and ask for a quote; and do shop around for the best quote. Quotes can vary over a wide range especially for small part runs. Probably best to inquire with the smaller shops for custom made springs.
