'Knowing very little about the Engine other than it is an inverted 6, I think Steve has it right on. If it has a scavenge pump; it may not be working or badly worn. The ranger is a notorious oil burner. I don't feel worn guides are guilty but if the scavenge pump is not working, the pressure from the guides or unseated rings will blow oil out of any engine. Is it possible that the pump was not correctly assembled? Are the plugs real oily? Remember, I really don't know much about a Ranger, But most engines work the same. Cy Galley - Chairman of Emergency Aircraft RepairA service project of EAA Chapter 75
Sent: Tuesday, June 09, 2015 4:44 PM
Subject: RE: [fairchildclub] Oil consumption on Ranger engine
Dan,
Here are some excerpts from previous posts on a similar subject. Some thought it was a scavenge pump problem and another had worn valve guides. I'm just parroting what I read as I am certainly not a mechanic.
Perhaps Cy Galley will log in.
Steve b.
" 3.5 years and 500 hours-my Fairchild 24R46 had its first flight this past weekend. What a thrill and a terrific flying airplane. The bad news is I used a tremendous amount of oil. Engine has a fresh overhaul as does all the accessories including the oil cooler. I thought it might just need to run to break in but I now think something else is going on. This morning I flew her for 45 minutes and used 2.5 gallons of oil.
Oil is coming out of the breather line and all over the belly. Oil cooler is warm but breather line is warmer than the oil return line. Any on have any suggestions??? PLEASE HELP!! JON
How fast do you turn the engine? I'll recommend not to run faster than 1900/1950rpm at cruise, for first flights and even later.. (depending on your props).
Was your scavenge pump OK?
are your exhausts pipes "greasy" somehow? Airy
Rings haven't seated. Might take up to 50 hours. If you have a worry after
about 10 hours, do a compression check to see which cylinder is bad. As for
now, probably all cylinders have excessive blow by.
If you have a CHT gage, when the rings seat, the Cylinder Head Temperature will show a marked drop in
temperature. Do you have a scavenge pump and is it turning? Cy Galley
When I bought the plane It used a lot like yours and I lived with it for a
while. I checked the rpm (using a model aircraft tach) and gauge rpm there was a difference!!!!
I thought I was setting to odd but the actual was much higher........... as soon as I bought the rpm back to the book figure the consumption reduced
...................... but it was still blowing it out the breather at anything
from 3 to 6 litres a hour.................... not good for touring. This winter I have performed a proper top end overhaul and and changed the valve guides as they were badly worn............. the piston rings and the usual
de-glazing of the cylinders and the difference is amazing.............. I can't remember when I last put oil in her.
When I first bought her she was meant to have had a top end overhaul but they obviously hadn’t done the valve guides... as they were very worn. The strange thing was the compressions were ok?
I am sure the guys will have an answer for you but this turned out to be my particular problem others I am sure will have other solutions.
