'Good, solid, information. Thank you Cy. Have not read both bolt specifications, but I'm thinking they are the same material, finish and thread tolerances except for the thread length.
On Friday, April 10, 2015 4:54 PM, "'Cy Galley'
cgalley@mchsi.com [fairchildclub]" wrote:
An bolts are Acceptable BUT with a wood prop one must be very careful one doesn't bottom out the threads. A true prop bolt has longer threads, but ANs work very well if you are aware of the limited thread length. Cy Galley - Chairman of Emergency Aircraft RepairA service project of EAA Chapter 75
Sent: Friday, April 10, 2015 1:34 PM
Subject: Re: [fairchildclub] Re: Prop hub bolts Just off the phone with SensenichIf your running a 8 bolt Warner Hub (7900) the AN6-51A is an acceptable alternate to the original bolts supplied.NOTE*** Please use this as a reference, contact Sensenich 813-752-3711 ask for Charlie Jim ChybickiMidwest Aeronautique LLCUC-61K USAAF# 43-1496 / RAF# HB690
Joe@Preston-Company.com [fairchildclub]"
To: "
fairchildclub@yahoogroups.com"
Sent: Friday, April 10, 2015 5:52 AM
Subject: Re: [fairchildclub] Re: Prop hub bolts You have to look at the Prop manufacturers installation guide. Sensenich for example has all of the props and bolts listed on their guide.Joe
Sent from my iPad Mini
On Apr 9, 2015, at 23:22, Ranchaero Wing Shop
david@ranchaerowingshop.com [fairchildclub] wrote:
AN5018? Sounds like a special bolt. But mine are 5" long. I'll check it again and measure the prop to be sure the bolts I think are prop bolts are actually that and not something else. I went looking through the Fairchild parts book for that number today but didn't see it. It showed the hub and the bolts but I couldn't find a number for the bolts. It was the end of the day so maybe tomorrow I'll see more than I could see today! haha Thanks for your help.
David
On 4/9/2015 6:16 PM,
cagog@yahoo.com [fairchildclub] wrote: David, The propeller hub bolts are AN but not AN7-?? standard bolts. They are AN5018 boltsFIXED PITCH WOOD PROPELLER and TEST CLUB. I measured a bolt I have for my PT-26propeller hub to determine the exact part number for you, it is a AN5018-20-229.(7/16 dia. length from under the head to end of threads 7-5/32) If your dimensions are different I can look up the appropriate partnumber from the AN standard drawings. I would check the RANGER parts book for the correct bolt number. If it is just AN the Part number for the bolt you describe is AN76A5(47/64 long) or AN76A6(57/64 long). But I would need to verify per IPC to be sure. Ryan
www.avast.com #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301 -- #ygrps-yiv-1207284948yiv1775883301ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp #ygrps-yiv-1207284948yiv1775883301hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp #ygrps-yiv-1207284948yiv1775883301ads { margin-bottom:10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp .ygrps-yiv-1207284948yiv1775883301ad { padding:0 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp .ygrps-yiv-1207284948yiv1775883301ad p { margin:0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mkp .ygrps-yiv-1207284948yiv1775883301ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ygrp-lc { font-family:Arial;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ygrp-lc #ygrps-yiv-1207284948yiv1775883301hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ygrp-lc .ygrps-yiv-1207284948yiv1775883301ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span { font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span span { color:#ff7900;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301activity span .ygrps-yiv-1207284948yiv1775883301underline { text-decoration:underline;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach div a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach img { border:none;padding-right:5px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301attach label a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301bold a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 dd.ygrps-yiv-1207284948yiv1775883301last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 dd.ygrps-yiv-1207284948yiv1775883301last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 dd.ygrps-yiv-1207284948yiv1775883301last p span.ygrps-yiv-1207284948yiv1775883301yshortcuts { margin-right:0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301attach-table div div a { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301attach-table { width:400px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a:active, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a:hover, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301file-title a:visited { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a:active, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a:hover, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div.ygrps-yiv-1207284948yiv1775883301photo-title a:visited { text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 div#ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg #ygrps-yiv-1207284948yiv1775883301ygrp-msg p a span.ygrps-yiv-1207284948yiv1775883301yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301green { color:#628c2a;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 o { font-size:0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301photos div { float:left;width:72px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301reco-category { font-size:77%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301reco-desc { font-size:77%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 .ygrps-yiv-1207284948yiv1775883301replbq { margin:4px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg select, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 input, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg pre, #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 code { font:115% monospace;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-mlmsg #ygrps-yiv-1207284948yiv1775883301logo { padding-bottom:10px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-msg p#ygrps-yiv-1207284948yiv1775883301attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-reco #ygrps-yiv-1207284948yiv1775883301reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-sponsor #ygrps-yiv-1207284948yiv1775883301ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-text { font-family:Georgia;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-text tt { font-size:120%;} #ygrps-yiv-1207284948 #ygrps-yiv-1207284948yiv1775883301 #ygrps-yiv-1207284948yiv1775883301ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1207284948
