				Ranger oil fittings
				Posted: Wed Nov 19, 2014 8:38 pm
				by Ranchaero Wing Shop
				'Anyone know where I can get oil fittings? I need some AC-851-16 and
 AC-852-16 fittings. These are 3/4 pipe to 1" ID hose 45deg and 90deg
 fittings used in several places in the oil system of the Ranger.
 David'
				Re: Ranger oil fittings
				Posted: Wed Nov 19, 2014 9:07 pm
				by Cy Galley
				'My 1948 Bellanca used those Air Corp fittings.  However, in a couple of places someone used AN fittings as the Pipe ends are the same.  You just have to use the proper AN to hose.  Now I am aware you are trying to make it historically right; so keep looking for the Grey not the Blue fittings.  I'd check with my Ranger engine parts source.      Cy Galley - Chairman of Emergency Aircraft RepairA service project of EAA Chapter 75
Sent: Wednesday, November 19, 2014 8:39 PM
Subject: [fairchildclub] Ranger oil fittings
David'
				Posted: Wed Nov 19, 2014 9:28 pm
				by Curt Kinchen
				'You are looking for AN842 and AN844-16 fittings, 90 and 45 respectively.  Letter suffix for material type, brass(none), aluminum(D orW), steel(S).  Bunch of brass 90 degree ones on eBay right now for $10.
Found them at Skygeek, but really pricey.   One type at Wicks.  Bet Lance Aircraft has them.
Curt
Sent from my iPad
 David
				Posted: Thu Nov 20, 2014 6:37 am
				by Cy Galley
				'If you replace the AC with AN  you must replace the line as well. Nut threads are different as well as the sealing angle.
Sent: Wednesday, November 19, 2014 9:29 PM
Subject: Re: [fairchildclub] Ranger oil fittings    You are looking for AN842 and AN844-16 fittings, 90 and 45 respectively.  Letter suffix for material type, brass(none), aluminum(D orW), steel(S).  Bunch of brass 90 degree ones on eBay right now for $10.  Found them at Skygeek, but really pricey.   One type at Wicks.  Bet Lance Aircraft has them.   Curt
Sent from my iPad
On Nov 19, 2014, at 9:38 PM, Ranchaero Wing Shop
David
				Posted: Thu Nov 20, 2014 8:45 am
				'                   These are for oil lines to the oil       cooler and rear of engine. Somebody please correct me if I'm       wrong, but I believe I need the "AC" and brass.
       David
       On 11/20/2014 4:37 AM, 'Cy Galley'
From:                       fairchildclub@yahoogroups.com                       [
                                 Sent from my iPad
                                     David
