F24R P-Lead Junction Box
Posted: Mon Oct 13, 2014 12:08 pm
				'Hi Allthe UC-61K restoration in coming along gingerly.  Funny how work/family/life always seem to impede in spending time working on the plane.As we assembly the new polished firewall, and staying with our return to military stock as close as possible, I was wondering if anyone had the following items:
1. UC-61K specific wiring diagram. the ones in the military IPC seem to AN01-115CA-4 seem to miss the wire harness make up for UC-61Kthere is another Wiring Diagram in Erection Manual AN01-115CA-2 for UC-61K specific Figure 95 page 74 , but there is NO breakdown for wire sizes, lengths or components. I can figure out most from the UC-61A wire diagram from Figure 94 page 73, but it does not show any of the changes or additions for the UC-61K. We checked the Drawings from the Group CD and the films we have from the Smithsonian, and still can not find the breakdown for the UC-61K specific wire diagram.
2. our plane is missing the Junction Box for P-Leads that attaches to engine side of Fire Wall. see IPC AN01-115CA-4 figure 62 item 1 on page 66 Fairchild Part number on page 69 is 48622, does anyone have one of these or can you share a newer manufacture part number or similar item?
3. is the Master Switch seen IPC AN01-115CA-4 figure 62 item 2on page 66 ,part number on page 69 is 705-B (Western Electric?) is this used on Ranger powered aircraft as well? does anyone have one of these or can you share a newer manufacture part number or similar item?
thanks! I will try to add IPC pictures to the Group photo albums under UC-61.
Thanks!Jim ChybickiMidwest Aeronautiques LLCUC-61K USAAF# 43-14964 / RAF # HB-690
