Wiring, Staples?
Posted: Sat Oct 11, 2014 6:45 am
by tdrager
'How do we route electrical wiring in the wing?
It looks like the previous owner used staples to hold down the wire bundle to the wood spar. Or do we use current AC part 43 practices?
They also routed wire within 1 inch of the fuel tank under the felt tank holder. Current rules prohibit routing wiring that close.'
Re: Wiring, Staples?
Posted: Sat Oct 11, 2014 7:01 am
by Andrew Budek-Schmeisser
'Use current practice for the wiring. It can save you headaches when
you sell the aeroplane.
It's my understanding that no judging boy will deduct points for a
documented "safety of flight" change - could anyone verify this?
On 10/11/14, tldrag1@gmail.com [fairchildclub]
Posted: Wed Oct 15, 2014 12:36 pm
by robert Etter
'It sound like someone did some creative wiring.  When I took my wings apart, one UC-61 & 1 pre-war civilian, both had the wiring bundle came out of the junction box and for the most part stayed on the back side of the rear spar all the way to the wing tip.  With the usual exceptions.  The fuel tank sending unit wiring went under the rear spar adjacent to the butt rib, then out along the anti-drag wire.  The landing light wiring ducked under the rear spar in the vicinity of the lift strut attach point.  All of the wiring was attached the "U" shaped  electrical staples.  Several areas were wrapped with friction tape.  I have some photos of the left UC-61 wing prior to it being taken apart.  It may show much of the original installation.  Any way, I wired the right wing in the same fashion as the left wing.  There is friction tape from the junction box to just outboard of the wing attach fitting on the spar, in the area of the flap extension stuff.  You may find some of my photos on the CD that Jamie put together, if you can't find it there, Let me know and I'll burn a CD with all of my older stuff and some new old stuff of both wings that I built.  The only thing that I did differently was the color of the staples that I used was brown or white, and I think Fairchild used black.  And I used a Grimes ST-1220 landing light and the factory used a ST-250.Both of my wing are 100% new wood, compression struts, drag/anti-drag wires, and aileron/flap hardware OE.  All nuts, bolts, washer and bushings are new.Bob775-482-9243
On Saturday, October 11, 2014 6:01 AM, "Andrew Budek-Schmeisser tempusfugit02@gmail.com [fairchildclub]" wrote:
#ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334 -- #ygrps-yiv-616842670yiv0769898334ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mkp #ygrps-yiv-616842670yiv0769898334hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mkp #ygrps-yiv-616842670yiv0769898334ads { margin-bottom:10px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mkp .ygrps-yiv-616842670yiv0769898334ad { padding:0 0;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mkp .ygrps-yiv-616842670yiv0769898334ad p { margin:0;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mkp .ygrps-yiv-616842670yiv0769898334ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-sponsor #ygrps-yiv-616842670yiv0769898334ygrp-lc { font-family:Arial;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-sponsor #ygrps-yiv-616842670yiv0769898334ygrp-lc #ygrps-yiv-616842670yiv0769898334hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-sponsor #ygrps-yiv-616842670yiv0769898334ygrp-lc .ygrps-yiv-616842670yiv0769898334ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334activity span { font-weight:700;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334activity span:first-child { text-transform:uppercase;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334activity span span { color:#ff7900;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334activity span .ygrps-yiv-616842670yiv0769898334underline { text-decoration:underline;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 .ygrps-yiv-616842670yiv0769898334attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 .ygrps-yiv-616842670yiv0769898334attach div a { text-decoration:none;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 .ygrps-yiv-616842670yiv0769898334attach img { border:none;padding-right:5px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 .ygrps-yiv-616842670yiv0769898334attach label { display:block;margin-bottom:5px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 .ygrps-yiv-616842670yiv0769898334attach label a { text-decoration:none;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 blockquote { margin:0 0 0 4px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 .ygrps-yiv-616842670yiv0769898334bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 .ygrps-yiv-616842670yiv0769898334bold a { text-decoration:none;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 dd.ygrps-yiv-616842670yiv0769898334last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 dd.ygrps-yiv-616842670yiv0769898334last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 dd.ygrps-yiv-616842670yiv0769898334last p span.ygrps-yiv-616842670yiv0769898334yshortcuts { margin-right:0;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 div.ygrps-yiv-616842670yiv0769898334attach-table div div a { text-decoration:none;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 div.ygrps-yiv-616842670yiv0769898334attach-table { width:400px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 div.ygrps-yiv-616842670yiv0769898334file-title a, #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 div.ygrps-yiv-616842670yiv0769898334file-title a:active, #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 div.ygrps-yiv-616842670yiv0769898334file-title a:hover, #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 div.ygrps-yiv-616842670yiv0769898334file-title a:visited { text-decoration:none;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 div.ygrps-yiv-616842670yiv0769898334photo-title a, #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 div.ygrps-yiv-616842670yiv0769898334photo-title a:active, #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 div.ygrps-yiv-616842670yiv0769898334photo-title a:hover, #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 div.ygrps-yiv-616842670yiv0769898334photo-title a:visited { text-decoration:none;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 div#ygrps-yiv-616842670yiv0769898334ygrp-mlmsg #ygrps-yiv-616842670yiv0769898334ygrp-msg p a span.ygrps-yiv-616842670yiv0769898334yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 .ygrps-yiv-616842670yiv0769898334green { color:#628c2a;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 .ygrps-yiv-616842670yiv0769898334MsoNormal { margin:0 0 0 0;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 o { font-size:0;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334photos div { float:left;width:72px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334reco-category { font-size:77%;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334reco-desc { font-size:77%;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 .ygrps-yiv-616842670yiv0769898334replbq { margin:4px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mlmsg select, #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 input, #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mlmsg pre, #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 code { font:115% monospace;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-mlmsg #ygrps-yiv-616842670yiv0769898334logo { padding-bottom:10px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-msg p#ygrps-yiv-616842670yiv0769898334attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-reco #ygrps-yiv-616842670yiv0769898334reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-sponsor #ygrps-yiv-616842670yiv0769898334ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-sponsor #ygrps-yiv-616842670yiv0769898334ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-sponsor #ygrps-yiv-616842670yiv0769898334ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-text { font-family:Georgia;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-text tt { font-size:120%;} #ygrps-yiv-616842670 #ygrps-yiv-616842670yiv0769898334 #ygrps-yiv-616842670yiv0769898334ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-616842670
