				Bronze fuel strainer valve.
				Posted: Fri Aug 15, 2014 1:25 pm
				by dc871f
				'What I have appears to be the original fuel valve that screws in under the gascolator and operates from a pull handle on the instrument panel on a 1939 Ranger powered F24.Long story short, it leaks and have tried to clean it up but I'm guessing its reached the end of its 74 year life. Does anybody know where to source these bronze valves, or an STC that would be better?Thanks.David'
				Re: Bronze fuel strainer valve.
				Posted: Fri Aug 15, 2014 4:55 pm
				by mileslong2k
				'Hi David,Would you happen to have a picture of this valve? I don't have the valves but I frequent ePay a lot and look at different parts.Jim'
				Posted: Fri Aug 15, 2014 5:58 pm
				by Bob Webster
				'?        Hi David,   For what it is worth, I had a 46 F-24 and the fuel  stringer valve leaked like you mentioned.  Not a drip, drip, but a constant  moist seeping type thing.   I dismembered it and used some valve grinding  compound (fine) that I had and cured it in about 20 minutes.  Maybe you  have a bigger leak?   Bob
To: fairchildclub@yahoogroups.com       Sent: Friday, August 15, 2014 2:25    PM
Subject: [fairchildclub] Bronze fuel    strainer valve.
What I have appears to be the original fuel valve that screws in under the    gascolator and operates from a pull handle on the instrument panel on a 1939    Ranger powered F24.      Long story short, it leaks and have tried to clean it up but I'm guessing    its reached the end of its 74 year life. Does anybody know where to source    these bronze valves, or an STC that would be better?      Thanks.      David
				Posted: Fri Aug 15, 2014 6:48 pm
				by Cy Galley
				'We fixed an fuel valve at AirVenture by cleaning then lapping it with tooth paste.  A dab of grease and it was back to leakfree. Cy Galley - Chairman of Emergency Aircraft RepairA service project of EAA Chapter 75
Sent: Friday, August 15, 2014 7:00 PM
Subject: Re: [fairchildclub] Bronze fuel strainer valve.
What I have appears to be the original fuel valve that screws in under the gascolator and operates from a pull handle on the instrument panel on a 1939 Ranger powered F24. Long story short, it leaks and have tried to clean it up but I'm guessing its reached the end of its 74 year life. Does anybody know where to source these bronze valves, or an STC that would be better?Thanks.David
				Posted: Sat Aug 16, 2014 7:12 pm
				by dc871f
				'Its a running seep. I'll try the toothpaste method to see if I can get it to stop. It's labeled as Lunkenhiemer manufactured valve, bronze.I would like to find a nice replacement, but will see what I can do for this one.Thanks.'
