Finally.. and happiness is!
'I was unsure about how the firewall forward is supposed to be put together. Now all of my questions are answered. It is a good thing, I actually found the proper drawing. Also, you could say that I was over thinking the problem. A drawing, #48509, "cowl installation" had everything that I was looking for. Of course, everything that I thought I knew was incorrect. The guy that was second in line ahead of me didn't have it right. I would have had the engine mounting ring backward, the engine cowl ring & inner-engine cowl switched. It did run & fly fine that way. It pays to step through the CD from time to time, if for no other reason than to refresh your memory. Bob'
