'I use a wheelbarrow inter-tube on my standard 10" tire on my 24. Purchased at a local tire store. The stem alignment leaves something to be desired. This could be my installing it! Tried several times to get to line up, but stem rests against one side of the wheel which makes checking pressure and inflating a bit of a challenge. Also, the stem is a bit too long to allow for installing the small section of the dust cover over it.Roger StarrNC77630
On Sunday, June 8, 2014 8:23 AM, "
ptcurt@gmail.com [fairchildclub]" wrote:
The 90 degree metal stem won't work. You have to use the straight rubber stem and live with pushing it over and putting the cover plate over it.
I just replaced mine a month or so back and it seemed a little shorter than the previous tube stem and fit better. On the previous one and on my other PT it would bow the cover plate out.
I recommend having a spare tube handy.
The reason for my last replacement was a failed valve stem. Admittedly well over 10 years old, but I suspect the extra stress of pushing it over can't be good for it.
FYI, Desser took my return of the 90 degree metal stem tube without any issues. A friend ordered it for me when he was ordering one for his Stearman, which uses the 90 degree. Sent via BlackBerry by AT&T
coxs.gorrel@virgin.net [fairchildclub]"
Sender: fairchildclub@yahoogroups.com Date: 08 Jun 2014 04:15:32 -0700
To: ReplyTo: fairchildclub@yahoogroups.com Subject: [fairchildclub] UC61K 10 inch Tail Wheel Tire and Tube
Folks,
I have a a Variety Aircraft VGC 10 tail wheel hub (thanks to Steve Lawlor) and before I part with 'large bucks' was wanting to check specifically which tube I should use with this tire.
10.00 SC 8 PLY AERO CLASSIC CHANNEL TREAD AIRCRAFT TIRE (as stocked by Desser)
Was planning on the 'Channel tread' to try and reduce the tendency to shimmy and I'm not keen on the hub adapters as I am trying to stay close to original.
I am unsure about the 90* valve as it seems too long and does not fit well. Also, as Desser say- "Do not use if you have a fork. The alternate tube, 10.00 STRAIGHT RUBBER VALVE works in all applications". - but the Variety hub is not, by the look of it, suited to a straight valve - "Catch 22"!
Any/all comments/experiences on which combination of tire and tube work best, polite or otherwise, will be most welcome.
Thanks in advance
Frank #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754 -- #ygrps-yiv-319373597yiv7874842754ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp #ygrps-yiv-319373597yiv7874842754hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp #ygrps-yiv-319373597yiv7874842754ads { margin-bottom:10px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp .ygrps-yiv-319373597yiv7874842754ad { padding:0 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp .ygrps-yiv-319373597yiv7874842754ad p { margin:0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp .ygrps-yiv-319373597yiv7874842754ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ygrp-lc { font-family:Arial;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ygrp-lc #ygrps-yiv-319373597yiv7874842754hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ygrp-lc .ygrps-yiv-319373597yiv7874842754ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity span { font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity span:first-child { text-transform:uppercase;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity span span { color:#ff7900;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity span .ygrps-yiv-319373597yiv7874842754underline { text-decoration:underline;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754attach div a { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754attach img { border:none;padding-right:5px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754attach label { display:block;margin-bottom:5px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754attach label a { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 blockquote { margin:0 0 0 4px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754bold a { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 dd.ygrps-yiv-319373597yiv7874842754last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 dd.ygrps-yiv-319373597yiv7874842754last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 dd.ygrps-yiv-319373597yiv7874842754last p span.ygrps-yiv-319373597yiv7874842754yshortcuts { margin-right:0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754attach-table div div a { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754attach-table { width:400px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754file-title a, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754file-title a:active, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754file-title a:hover, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754file-title a:visited { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754photo-title a, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754photo-title a:active, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754photo-title a:hover, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754photo-title a:visited { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div#ygrps-yiv-319373597yiv7874842754ygrp-mlmsg #ygrps-yiv-319373597yiv7874842754ygrp-msg p a span.ygrps-yiv-319373597yiv7874842754yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754green { color:#628c2a;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754MsoNormal { margin:0 0 0 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 o { font-size:0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754photos div { float:left;width:72px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754reco-category { font-size:77%;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754reco-desc { font-size:77%;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754replbq { margin:4px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg select, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 input, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg pre, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 code { font:115% monospace;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg #ygrps-yiv-319373597yiv7874842754logo { padding-bottom:10px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-msg p#ygrps-yiv-319373597yiv7874842754attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-reco #ygrps-yiv-319373597yiv7874842754reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-text { font-family:Georgia;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-text tt { font-size:120%;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-319373597
