'All, The Fresno stock is not any good if they find any more at all. Get with Larry Trumpore a call. See below. I just sent a complete set to England. You will need to send him your shells (inner and outer). Do not damage them. They are expensive to machine. If you can’t get them out of the Alum mounts, send the entire mount assembly. He will press them out. They are not cheap. Larry has the Lord Drawings and the rubber specs. Very nice product. Ranger and Warner 145/165/185 Engine Bushings: Southland Manufacturing Corp. Owner: Larry Trumpore P.O. Box 350 Hope, NJ. 07844 Phone 908-459-5858 Cell: 201-919-4287 Jamie S. Treat A&P/IA
Fairchild Club CD ROM Editor
IAC 5, Chapter President
http://iac5.org
Kelly Airpark (CO15)
http://www.kellyairpark.com
Elbert, CO 80106 Hm/Hgr 303-648-0130
Cell 303-304-7937 Quote of the Month: The Cub is the safest airplane in the world; it can just barely kill you. - attributed to Max Stanley, Northrop test pilot
Sent: Wednesday, May 14, 2014 5:07 PM
Subject: Re: [fairchildclub] PT-19 Engine Rubber Mounts If you do a search, you'll find previous discussion on this topic. My recollection is someone did or was going to have some made. I bought NOS mounts from Fresno a few years back and had one fail/disbond. Replaced it with another and they seem to be doing OK. Probably hit or miss as they are pretty old. I don't see them listed in their Trade-a-Plane add any longer so maybe they aren't available?The original Fairchild boxes they came in, as always, are cool. On Wed, May 14, 2014 at 12:52 PM, 'Fritz Mehrer'
avdflyr@cox.net [fairchildclub] wrote: Hey guys, where do I find new engine rubber mounts for my PT-19/26 Fritz Oceanside, CA
ptcurt@gmail.com '
