PT-19 Ranger list of parts needed
Posted: Sat Apr 12, 2014 3:37 pm
				'          Following are the list of parts that I will need. I  have some of these items, but for the most part they're in pretty sad shape.  So I'd like to find something a little better than what I  have. The numbers given are from the Fairchild PT-19 Parts  Catalog.   -David     Exhaust manifold cowling Fig 91 page  98   1. 64107 - pipe, hotspot inlet 2. 64108 - bracket, hotspot outlet  tube 3. 64109 - Pipe, hotspot outlet 4. 64117-7 - Housing, upper 5. 64117-8 - Housing, lower 6. 64117-9 Shield & plate assembly 7. 64118 - Door, cylinder cooling cowl 8. 64119 - Cowl, exhaust - cooling  upper-inner 9. 64120 - Cowl, exhaust - cooling  upper-outer 10. 64121 - Cowl, exhaust - cooling  lower-inner 11. 64122 - Cowl, exhaust - cooling  lower-outer 12. 64123 - Cowl, exhaust - cooling upper -  rear 13. 64124 - Cowl, exhaust - cooling  lower-rear 14. 64125 - Pin, exhaust cooling cowl 16. 64127 - Plate, hot spot inlet tube 17. 64129 - Clip, rear baffle 18 - 64131 - Deflector 19 - 64132 - Spacer, cooling cowl rear     Oiler Cooler Fig. 79 page 88   4. 64142 - Bracket, oil cooler front 5. 64143 - Bracket, oil cooler rear 6. U-3160-D-5 Oil Cooler 7. FS102-33 Spacer (2) 11. 3265 Relief valve 12. AC 852-16 Elbow 13. AC 851-16 Elbow     Air Maze Fig. 94 page 100   1. Hose, Neoprene 3. 68634 - Door, duct 5. 68639 Clamp (2) 6. 68640 Elbow (carb) 7. 68641 Control (Shakespeare) 8. 1029 Swivel (A-3/32")  9. 68642 Screen (air maze) 10. 68645 Clip  '
