'Josh, The original master cylinder used with the Hayes brakes are not compatable with Cleveland disc brakes, the braking force can be calculated as follows, the pressure applied to the master cylinder divided by the area equals PSI. PSI applied to the caliper multiplied by area equals the pressure, and dont forget to calculate the pressure applied to the master cylinder with the mechanical advantage of the belcranks or levers used to actuate it. But that is all useless, If installing the 310 wheels and brakes the original Fairchild master cylinders are not matched because they move too much brake fluid in order to inflate the expander tubes of the original brakes. Removing one of the brake pads is not the answer; this will only decreases the braking surface area at the disc, not the pressure, it also increases the temperature of the brake pads which before brake fade occurs can cause a grabby braking action. Selecting the proper master cylinder and possibly changing bell crank ratio to achieve the correct pressure is key to get the proper braking action. the FARs tell us the braking action should be sufficiant enough to prevent the aircraft wheels from rotating at full power. I used the brakes of the Staggerwing as the basis for the Cleveland installation on my Fairchild. Jim Higham N81207 F24R46A-108
To: "
fairchildclub@yahoogroups.com"
Sent: Wednesday, January 1, 2014 6:28 PM
Subject: Re: [fairchildclub] Cleveland conversion with original master cylinders
Josh, Springer Aerospace has Redline brake kits for the Staggerwing series. Redline brake kits consist of Cleveland parts engineered by Springer for each application. Not sure, but perhaps the kits can be obtained without the master cylinder. Vintage airplanes have been put on their noses with Cessna 310 wheels because of excessive braking power. Best to leave brake engineering to the experts. On Wednesday, January 1, 2014 2:16 PM, "
mtnbound@gmail.com" wrote:
We are working on an early model staggerwing with the same hayes wheels and brakes that are on many fairchilds. Do any of you have experience with installing the cessna 310 wheels and brakes and utilizing the original master cylinders? I am specifically looking for a 337 that shows the braking energy available with te new brakes, and old master cylinders.
Thank you,
Josh #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537 -- #ygrps-yiv-1333253689yiv9897796537ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mkp #ygrps-yiv-1333253689yiv9897796537hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mkp #ygrps-yiv-1333253689yiv9897796537ads { margin-bottom:10px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mkp .ygrps-yiv-1333253689yiv9897796537ad { padding:0 0;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mkp .ygrps-yiv-1333253689yiv9897796537ad p { margin:0;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mkp .ygrps-yiv-1333253689yiv9897796537ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-sponsor #ygrps-yiv-1333253689yiv9897796537ygrp-lc { font-family:Arial;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-sponsor #ygrps-yiv-1333253689yiv9897796537ygrp-lc #ygrps-yiv-1333253689yiv9897796537hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-sponsor #ygrps-yiv-1333253689yiv9897796537ygrp-lc .ygrps-yiv-1333253689yiv9897796537ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537activity span { font-weight:700;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537activity span span { color:#ff7900;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537activity span .ygrps-yiv-1333253689yiv9897796537underline { text-decoration:underline;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 .ygrps-yiv-1333253689yiv9897796537attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 .ygrps-yiv-1333253689yiv9897796537attach div a { text-decoration:none;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 .ygrps-yiv-1333253689yiv9897796537attach img { border:none;padding-right:5px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 .ygrps-yiv-1333253689yiv9897796537attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 .ygrps-yiv-1333253689yiv9897796537attach label a { text-decoration:none;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 .ygrps-yiv-1333253689yiv9897796537bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 .ygrps-yiv-1333253689yiv9897796537bold a { text-decoration:none;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 dd.ygrps-yiv-1333253689yiv9897796537last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 dd.ygrps-yiv-1333253689yiv9897796537last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 dd.ygrps-yiv-1333253689yiv9897796537last p span.ygrps-yiv-1333253689yiv9897796537yshortcuts { margin-right:0;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 div.ygrps-yiv-1333253689yiv9897796537attach-table div div a { text-decoration:none;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 div.ygrps-yiv-1333253689yiv9897796537attach-table { width:400px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 div.ygrps-yiv-1333253689yiv9897796537file-title a, #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 div.ygrps-yiv-1333253689yiv9897796537file-title a:active, #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 div.ygrps-yiv-1333253689yiv9897796537file-title a:hover, #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 div.ygrps-yiv-1333253689yiv9897796537file-title a:visited { text-decoration:none;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 div.ygrps-yiv-1333253689yiv9897796537photo-title a, #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 div.ygrps-yiv-1333253689yiv9897796537photo-title a:active, #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 div.ygrps-yiv-1333253689yiv9897796537photo-title a:hover, #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 div.ygrps-yiv-1333253689yiv9897796537photo-title a:visited { text-decoration:none;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 div#ygrps-yiv-1333253689yiv9897796537ygrp-mlmsg #ygrps-yiv-1333253689yiv9897796537ygrp-msg p a span.ygrps-yiv-1333253689yiv9897796537yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 .ygrps-yiv-1333253689yiv9897796537green { color:#628c2a;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 .ygrps-yiv-1333253689yiv9897796537MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 o { font-size:0;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537photos div { float:left;width:72px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537reco-category { font-size:77%;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537reco-desc { font-size:77%;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 .ygrps-yiv-1333253689yiv9897796537replbq { margin:4px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mlmsg select, #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 input, #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mlmsg pre, #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 code { font:115% monospace;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-mlmsg #ygrps-yiv-1333253689yiv9897796537logo { padding-bottom:10px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-msg p#ygrps-yiv-1333253689yiv9897796537attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-reco #ygrps-yiv-1333253689yiv9897796537reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-sponsor #ygrps-yiv-1333253689yiv9897796537ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-sponsor #ygrps-yiv-1333253689yiv9897796537ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-sponsor #ygrps-yiv-1333253689yiv9897796537ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-text { font-family:Georgia;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-text tt { font-size:120%;} #ygrps-yiv-1333253689 #ygrps-yiv-1333253689yiv9897796537 #ygrps-yiv-1333253689yiv9897796537ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1333253689 '
