'O-85 blades, ie 85 inches. From the Fairchild 24 TCDS:
Propeller - Koppers Aeromatic --- --- 53 lbs. (-75) ---
Hub 220 with 0-85 blades.
(Landplane only) Parts List Assembly
No. 4321. Low pitch setting 10.3?
measured at 30 in. sta. Static rpm
at max. permissible throttle setting:
A-706
Page 4
Not over 2450; not under 2350. No
additional tolerance permitted.
Diameter: Not over 85 in., not under
83 1/4 in. (Oil cooler air ducts to be
modified and instrument panel placard
added in accordance with Fairchild
Dwg. 48734*). When Aeromatic propeller,
is installed, installation and operation
must be accomplished in accordance with
Koppers "Installation Procedure and
Operating Limitations" No. 6C.
On Mon, Apr 15, 2013 at 12:41 PM, denny.grundy wrote:
> Does any one have information on the propeller diameter for an Aeromatic
> F-220 propeller on a 200 hp Ranger?
> The Aeromatic F-220 blades can be made to a maximum diameter of 93".
> Denny Grundy
ptcurt@gmail.com
