--- In
fairchildclub@yahoogroups.com, David Keen wrote:
> Tony,
> I have been working with Serv Aero and have been provided the engine mount drawing for the Jacobs 755. I will Be installing a 755 on my aircraft N28523. Currently working a field approval for the supporting engine change. I can help if you need it.
> David
> Sent from my iPhone
> On Dec 26, 2012, at 9:34 PM, Patricia Banks wrote:
> > Tony,
> > I'm all for keeping the classics as original as possible but there are times when parts availability and economics make that very difficult. You are facing a problem that will eventually be the demise of many Warner powered 24s. I own one of the few flying Jacobs 755B2 powered F-24s around. Once upon a time, the Continental and Jacobs engines were pretty common on the F-24. This was before the resurgence of the airplane as a desirable classic, rather than an economical bush plane and work horse. I believe that there are a few owners in the group that are working on reviving the Jacobs installation. Its by far the most practical conversion, especially since it was once an STC, and the data is available to reconstruct the conversion. An M-14 would not be viable in my opinion. As mentioned by others, too heavy, wrong rotation, experimental, high cost, parts availability, etc. Even the Jake conversion has limitations due to gross weight and CG
> > issues. Its not for everyone, but I really like my Jake powered 24, it has incredible short field and climb performance, its unique, parts are readily available, and its just a blast to fly.
> > New Jake and Continental engines and parts can be purchased from Air Repair Inc. and Radial Engines Limited. I think the group will first encourage you to stick with the Warner for originality, and they will work to support your needs. If you are dead set on a conversion, consider the wheels that have already been invented with the Jake and Continental conversions. You might even find a project or flying converted 24 for a good price. You would have a ton of money invested in doing a conversion from scratch.
> > Just another opinion for what its worth ...
> > If you google N4263S, or look in the Fairchild group photo archive, you can see what a Jake powered 24 looks like. I think the bigger Jake greatly improves the proportions of the plane.
> > Matt
> > --- On Tue, 12/25/12, lowea1@... wrote:
> > From: lowea1@...
> > Subject: [fairchildclub] Russian or Chinese Radial on F24W?
> > To: "Fairchild Club"
> > Date: Tuesday, December 25, 2012, 9:29 PM
> > Anybody out there have any info on putting one of the Russian or Chinese radials, Vedeneyev AI-14 or M14P, or Housai HS-6A, on at F24W? I wonder if I should give up on my Warner 165, and what the consequences might be if I went to one of these more modern and plentiful radials. Aybody out there done this yet? Thanks. Tony Lowe
> > Yahoo! Groups Links
