advise
Posted: Fri Dec 07, 2012 12:41 am
'If a fellow is restoring a F24 46R, what color should the frame be painted?
Jeff
Jeff Whitesell
topfun@fivetogether.com'
Jeff
Jeff Whitesell
A Forum for all interested in vintage Fairchild Aircraft
https://board.fairchild-club.org/
'--- In fairchildclub@yahoogroups.com, james chybicki wrote:
> I've seen black, red, green, blue, Zinc Yellow....
> I guess it all depends on your need
> My frame was zinc-green primer and then Polurathane Green over that to match our WOrld War 2 color scheme on our UC-61K
> Jim Â
> From: Jeffrey Whitesell
> Sent: Friday, December 7, 2012 12:40 AM
> Subject: [fairchildclub] advise
> Â
> Jeff
> Jeff Whitesell
> mailto:topfun%40fivetogether.com
match our WOrld War 2 color scheme on our UC-61K>
painted?> Jim Â
> Â
> Jeff
> Jeff Whitesell
'On Dec 7, 2012, at 8:09 AM, Cy Galley wrote:
> Funny, The military used Yellow Zinc chromate for most anything on aircraft.
> Today, Epoxy primers are a must as the paint solvents and fabric liquids
> will dissolve most anything leaving the substrate unprotected. Use whatever
> color you think you want or need.
> From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
> On Behalf Of Tom_Downey
> Sent: Friday, December 07, 2012 9:20 AM
> Subject: [fairchildclub] Re: advise
> Actually the fuselage frame is 4130 steel, Zink Chromate is for aluminum and
> Iron oxide primers are for steel.
> , james chybicki
> > My frame was zinc-green primer? and then Polurathane Green over that to
> match our WOrld War 2 color scheme? on our UC-61K
> > Jim? ?
> painted?
> > Jeff
> > Jeff Whitesell
Jeff Whitesell
'On Dec 7, 2012, at 8:52 AM, Jeffrey Whitesell wrote:
> Thanks, gentlemen. what your feeling on powdercoating?
> Jeff
>> , james chybicki
>>> Jim Â
>>> Â
>> painted?
>>> Jeff
>>> Jeff Whitesell
> Jeff Whitesell
> Jeff
> Jeff Whitesell
> topfun@...
'--- In fairchildclub@yahoogroups.com, Jim wrote:
> Powder coating prevents proper inspections in the future. It hides cracks
> Jim Higham
> N81207
> F24R46-108
> > Jeff
> >> , james chybicki
> >>> My frame was zinc-green primerÃ? and then Polurathane Green over that to
> >> match our WOrld War 2 color schemeÃ? on our UC-61K
> >>> JimÃ? Ã?
> >>> Ã?
> >> painted?
> >>> Jeff
> >>> Jeff Whitesell
> > Jeff Whitesell
> > topfun@...
> > Yahoo! Groups Links
aircraft.>
> Jim Higham
> N81207
> F24R46-108
> > Jeff
liquids> >>
whatever> >> will dissolve most anything leaving the substrate unprotected. Use
aluminum and> >> Subject: [fairchildclub] Re: advise
to> >> , james chybicki
> >>> JimÃ? Ã?
[Non-text portions of this message have been removed]'> >>
> >>> Ã?
> >> painted?
> >>> Jeff
> >>> Jeff Whitesell
> > Jeff Whitesell
> > topfun@...
> > Yahoo! Groups Links
'On Dec 8, 2012, at 2:10 AM, higgshunter wrote:
> Are you asking about original colors or what others are doing? PM sent.
> > Jeff
> > Jeff Whitesell
> > topfun@...
Jeff Whitesell
