On Nov 30, 2012, at 9:08 AM, james chybicki wrote:
> HI Jeff
> by chance do you have a 2 1/4 fairchild oil pressure indicator?
> Jim Chybicki
> From: Jeffrey Whitesell
fairchildclub@yahoogroups.com
> Sent: Thursday, November 29, 2012 11:01 PM
> Subject: Re: [fairchildclub] NEW MEMBER -- reltney20
> Hello John
> I have a box of 3 in one guages - from all sorts of airplanes. If you can give me a part number, I may have one that'll work for you...
> Jeff Whitesell
> 805-444-2257
> On Nov 29, 2012, at 1:13 PM, John Ellis wrote:
> > Hi Jim,
> > I have a test stand I run Ranger Engines on aftere overhaul. I need the 3
> > in 1 temp. and pressure gauge assemble.
> > Would you sell just that part, if so, how much for it.
> > Thanks, John
> > ----- Original Message -----
> > From: "james chybicki"
> > To:
> > Sent: Thursday, November 29, 2012 1:32 PM
> > Hi All
> > I have the following PT parts here in Chicago:
> > 61515 Tube-front operation. 605004 cowl right side. left and right mags for
> > a RANGER (cores). fuel cock UNITED AIRCRAFT PN UA-499478. hand cranks. 62161
> > stick and 6282-3 socket. Oil cooler 6" dia.200 HP Ranger.(core, had been
> > dropped and has a flat spot on upper leading edge)PN 61301 drag link for
> > Fairchild PT's. 60544 Tail fairing-vertical. Fwd and Rear custom seat
> > cushions. 60543 tail fairing-upper.3 in 1 temp & pressure gauge. Various
> > Push Tubes
> > Stick and assy forward and aft assembly from a wrecked PT. lots of good
> > parts on it. Wobble Pump (core)Ranger Fuel Pump (core-broken shaft)
> > Pictures avialable
> > F24-
> > 1 L/H Wheel pant that has seen better days, but can be used as a pattern?
> > Old C8E oil Tank
> > I need a good used PT-19 Pitot tube
> > thanks!
> > Jim Chybicki
> > UC-61K 43-14964 / RAF ArgusIII HB-690
> > From: Reltney
> > To: "
fairchildclub@yahoogroups.com"
> > Sent: Thursday, November 29, 2012 11:44 AM
> > Subject: RE: [fairchildclub] NEW MEMBER -- reltney20
> > No, I am building up a small spare part collection. What are you looking
> > for?
> > Sent from my iPad
> > Yahoo! Groups Links
> Jeff Whitesell
topfun@fivetogether.com
Jeff Whitesell
