e: [fairchildclub] Re: Tach drive tang
Posted: Wed Jul 25, 2012 7:30 pm
'Mike,
Sending copy of drawing of tach drive assembly. If you have both gears in the housing, all you need is the cable to second tach.
John
John
Sent: Wednesday, July 25, 2012 10:28 AM
Subject: [fairchildclub] Re: Tach drive tang
> Hmmm.....maybe I'm complicating this too much. I'm trying to Drive a second tach in the front cockpit of my Great Lakes. My Ranger appears to have a dual tach drive. Does anyone have that type of setup? It looks like all I have to do is pull the cap off the unused tach drive adapter and install the cable to the second tach. Can it really be that simple?
> Any advice?
> --- In fairchildclub@yahoogroups.com,
> "Mike" wrote:
>> I'm trying to find the short "I" tang that goes between the engine tach drive and a dual drive unit. Little short gizmo with an "I" tang at both ends. Ain't had much luck. Anyone here can help?
