Page 1 of 2
Ranger Engine Parameters
Posted: Sun Jun 24, 2012 7:13 pm
by super_dan2000
'I JUST completed a restoration on my 1939 Fairchild 24. It has a Ranger engine.
Everything seems to run perfectly; I've got about 5 hours ground time on the engine, and have flown it about 2 hours. Oil consumption is nil, and it hasn't missed a beat.
Just wondering, the oil temp is consistent around 190 degrees F, and the CHT is steady around 250. Is this normal?
The days have been hot and fairly humid, but I can't seem to find any information on normal operating ranges of the engine...
Any input would help. Thanks!
-Dan'
Re: Ranger Engine Parameters
Posted: Sun Jun 24, 2012 7:25 pm
by ptcurt@gmail.com
'Something seriously wrong if its not using any oil:)
Oil temp is a bit high as desired max is 170, but redline is 200. It is still breaking in so the temp may come down.
Sent via BlackBerry by AT&T
Sender: fairchildclub@yahoogroups.com
Date: Mon, 25 Jun 2012 01:12:56
Reply-To: fairchildclub@yahoogroups.com
Subject: [fairchildclub] Ranger Engine Parameters
-Dan
Posted: Mon Jun 25, 2012 9:43 am
by dc871f
'Do you plan to use straight mineral oil after the break in period?
What is your oil pressure been running at?
Just curious.
> From: "super_dan2000"
> -Dan
Posted: Mon Jun 25, 2012 10:04 am
by Cy Galley
'So what is wrong with 190°?
On Behalf Of dc871f
Sent: Monday, June 25, 2012 10:43 AM
Subject: [fairchildclub] Re: Ranger Engine Parameters
Just curious.
engine.
> -Dan
Posted: Mon Jun 25, 2012 10:24 am
by Jack Threadgill
'For what it is worth, my Ranger in a PT-19 runs about 160 to 170 deg's F
depending on OAT. CHT's are about 280 deg's F.
Now that mine is broken in, I have adjusted the oil pressure to be 50 psi
when hot and I use Aeroshell W120, 60 wt oil.
Jack M. Threadgill
1602 Brook Hollow Dr
Bryan, Texas 77802
979-779-7155
threadgl@suddenlink.net
On Behalf Of dc871f
Just curious.
engine.
> -Dan
Posted: Mon Jun 25, 2012 11:05 am
by super_dan2000
'Jack,
Thanks for the info. From what I've gathered everything is running as it should. I've hit 190 oil temp while doing touch-and-gos, and really working the engine... It drops at cruise.
Thanks again,
-Dan
> Jack M. Threadgill
> Bryan, Texas 77802
> 979-779-7155
> threadgl@...
> On Behalf Of dc871f
> Just curious.
> > To: >
> engine.
> > -Dan
Posted: Mon Jun 25, 2012 11:15 am
by super_dan2000
'Hello!
The engine has about 150 hours SMOH, so its well broken in. Oil pressure at cruise is right around 50, higher at takeoff, lower at idle.
> Just curious.
> > To:
> > -Dan
Posted: Mon Jun 25, 2012 11:21 pm
by Mike Danielle
'Wondering who did the o'haul. My freshly redone (Antique Aero) C-5 runs
about the same oil temp as yours. Brad Ball says not to worry about that
temp with his rebuilds. I don't have a cht gauge.
Ranger Mike
On Behalf Of super_dan2000
Sent: Monday, June 25, 2012 9:56 AM
Hello!
> Just curious.
> > To:
engine.
> > -Dan
Posted: Wed Jun 27, 2012 9:45 pm
by Bob
'Dan,
I think you are doing just fine. Many engine pros want engine oil temp of at least 185 degrees, in order to remove moisture from the engine oil. I have a 1939 with a large oil cooler hanging out the bottom, and can't get my oil over 160 degrees unless I block off part of the cooler.
Your 250 degree Cyl Head Temps are just fine. I recall that the max climb temp is about 425 and max cruise temp is about 350. The hottest cylinders on the engine are #2 and #5. There is a factory mod to the removable baffle that is supposed to help cool #5.
Webster, MN
1939 Fairchild 24K
> -Dan
Posted: Thu Jun 28, 2012 4:57 am
by super_dan2000
'Mike,
Sorry I can't help you there; the engine was rebuilt back in the 1970s and crated... We just checked it out - everything is normal... I'd have to go through the stacks of paperwork to figure out who did the overhaul and when
> Ranger Mike
> Hello!
> > Just curious.
> > > To:
> engine.
> > > -Dan
