Battery question
Posted: Fri Jan 13, 2012 2:03 pm
by Joe Preston
'Just curious as to what battery you guys are using for the Warner
powered birds? Any thoughts?
Joe
Re: Battery question
Posted: Fri Jan 13, 2012 2:27 pm
by looping.jp@voila.fr
'Hi,
And for the Ranger R46 ?
Many thanks
Jean-Pierre
> Joe
Posted: Fri Jan 13, 2012 5:19 pm
by n244ms@aol.com
'Joe,
I am using the Concorde RG-35AXC in my 24W-40 and have had very good luck with it. It has the extra cranking power, maintains voltage, and is 4 years old.
Mike Still
To: fairchildclub
Sent: Fri, Jan 13, 2012 8:03 am
Subject: [fairchildclub] Battery question
Joe
Posted: Sat Jan 14, 2012 1:53 pm
'Hi,
Your 24W use 12 volt power or are you using 2 batteries (I see that the Concorde is a 12 Volt battery)?
Many thanks
J-Pierre
--- In fairchildclub@yahoogroups.com, n244ms@... wrote:
> Joe,
> Mike Still
> From: Joe Preston
> To: fairchildclub
> Joe
Posted: Sat Jan 14, 2012 6:24 pm
by n244ms@aol.com
'12 Volt system
To: fairchildclub
Sent: Sat, Jan 14, 2012 7:53 am
Subject: [fairchildclub] Re: Battery question
Hi,
Many thanks
J-Pierre
> Joe,
> Mike Still
> From: Joe Preston
> To: fairchildclub
> Joe
Posted: Sat Jan 14, 2012 6:43 pm
by burnmcc@aol.com
'For what it is worth, I am using Concorde RG batteries in all my aircraft, and recommend them to all my customers as well. I have used them since they came out, and have found them to have better cranking power and reliability, with no negatives that I have seen, The only caveat is to understand the charging requirements, and use an appropriate charger. I have one in the 24G now and aas all my other experience, it is working just fine.
Bill McClure
To: fairchildclub
Sent: Sat, Jan 14, 2012 7:24 pm
Subject: Re: [fairchildclub] Re: Battery question
12 Volt system
To: fairchildclub
Hi,
Many thanks
J-Pierre
> Joe,
> Mike Still
> From: Joe Preston
> To: fairchildclub
> Joe
Posted: Sun Jan 15, 2012 11:27 am
by bradleybormuth
'We are using Concord RG AXC batteries in all of our planes now (except the 24W-40 only because the Gill POS still gets the job done). The concord is a MUCH better battery and is light years ahead of Gill for Lead-Acid batteries. Properly maintained, they will last decades.
> Joe
