Right side fuel valve for F-24
Posted: Fri Oct 14, 2011 6:37 am
by dc871f
'I'm in need of a fuel valve for the right side. I was searching about 7 months ago and the only valve I could find was one that had male and female fittings.
Mine has 2 female fittings. Any help would be appreciated, thank you.'
Re: Right side fuel valve for F-24
Posted: Fri Oct 14, 2011 7:15 am
by Airy Millet
'Is this valve really destroyed?
It may be possible to re-seat averything to make it work properly? no?
(I did it some years ago on our right side valve too).
Airy
Date: Fri, 14 Oct 2011 12:37:31 +0000
Subject: [fairchildclub] Right side fuel valve for F-24
Posted: Fri Oct 14, 2011 8:24 am
by dc871f
'I had an old valve that I tried that on with valve compound and failed miserably at it. I read where guys were getting it like glass, but I had no luck. If I try it again on the valve thats leaking and mess it up, then I'm hosed.
Darn antiques, but someone has to fly them.....
> Airy
> From: dc871f@...
Posted: Fri Oct 14, 2011 8:58 am
by james chybicki
'I have 4 sets of  NEW old Surplus Imperial Fuel valves left with the Y-fitting as seen in the UC-61 /F24 parts catalog page 59 figure 53 items 1&2.
If you need one, or more information please contact me at rampratone(at) yahoo.com
Jim Chybicki
UC-61K 43-14964
ARGUSIII/HB-690
Sent: Friday, October 14, 2011 7:37 AM
Posted: Fri Oct 14, 2011 9:10 am
by Patricia Banks
'I just went through the process of reworking my valves. They had become so difficult to turn that I was afraid I was going to become the subject of an NTSB report. On disassembling the valves I found that they had some deep scars and metal transfer. No wonder they were so difficult to turn. I had read about surfacing the valves with valve grinding compound. I went to NAPA and purchased some oil based compound and went to work. It only took about 30 seconds to realize that the grinding compound might not be the best choice. Remember that grinding compound is designed for grinding valves and seats with a rockwell hardness in the range of 45 HRC. We are trying to cut and polish soft brass. I found that the compund left deep scratches in the cone and body. BTW .. I chucked the cone and shaft in a battery drill to spin it in the seat which worked great. I thought I had ruined the first valve so my recovery was to use some sticky backed wet sandpaper of
various grits. I cut small strips and wrapped the cone, with no overlap, and used it to polish the seat. Water keeps the paper clean and helps it cut. It will load up with the soft brass pretty quickly. Once you get a pattern of the strip width and length its easy. Then I held the paper around the cone and polished it being careful not to round the corners over. I then used ordinary red and white rubbing compund to final polish the two pieces together. A very diligent cleaning and some fuel lube and the valves are as smooth as butter and leak free. Just my experience for what it is worth. I sure feel a lot better about the valves when flying now... well worth the effort.
Matt
F24-w46
--- On Fri, 10/14/11, dc871f wrote:
Subject: [fairchildclub] Re: Right side fuel valve for F-24
Date: Friday, October 14, 2011, 10:24 AM
> Airy
> From: dc871f@...
Posted: Fri Oct 14, 2011 9:23 am
by Cy Galley
'Did you use some fuel lube or ez turn or just plain grease when assembling?
This generally stops the leaks but will not last as well as a good
re-lapping using toothpaste.
www.eaa75.com
On Behalf Of dc871f
Sent: Friday, October 14, 2011 9:24 AM
hosed.
, Airy Millet
> Airy
> From: dc871f@...
fittings.
Posted: Fri Oct 14, 2011 10:36 am
by cen56258
'Cy,
I am surprised tooth paste was not brought into the discussion earlier. I have used "Smoker's Toprol" for years for lapping brass fuel vavlves. It's just a wee bit more agressive than plain toothpaste.
Wes K
