				Technical Data
				Posted: Tue Oct 11, 2011 8:22 am
				by Jeremy Harris
				'I am in need of any tech data, 337's, or any other info on a Warner 145 to 165 conversion on a 1934 C8C. The FAA is requiring more info for certification, any help is greatly appreciated. I am also in need of a reasonably priced, serviceable 165 cowling.'
				Re: Technical Data
				Posted: Tue Oct 11, 2011 9:34 am
				by John Duncan
				'Hello Jeremy,
 Sorry, I do not have any tech data related to a conversion from a 145 to 165.  But, I may have a 337 detailing a conversion from a W-145 to W-185 on a 1937 F-24.  Let me know if you think this 337 will be of use to you.
 I e-mailed pictures of the cowl spinning.  Please confirm if you received them, and advise if your customer has any interest.  If not, I will consider the matter closed.
 Kindest Regards,
 JD
fairchildclub@yahoogroups.com
fairchildw9@yahoo.com
 Date: Tue, 11 Oct 2011 14:21:51 +0000
 Subject: [fairchildclub] Technical Data
				Re: Technical Data
				Posted: Tue Oct 11, 2011 1:00 pm
				by frank gochenauer
				'Hi JohnI came late to this conversation.  Do you have cowl spinning for a 1940 Fairchild 24 with aWarner 165.FrankG
 > From:
johnaduncan@msn.com
 > Date: Tue, 11 Oct 2011 09:34:45 -0600
 > Subject: RE: [fairchildclub] Technical Data
 > Hello Jeremy,
 > Kindest Regards,
 > JD
 > From:
				Re: Technical Data
				Posted: Sat Oct 15, 2011 9:53 am
				by Tom_Downey
				'I have all the data that was required to place a Warner 165 on my 1937 F-24-G. NC19143
 The process of gaining a 1 time STC was used to do my aircraft. I do not know if the FAA will accept the F-24-G data or not, you will have to ask.
 These records are in a history file under the STC # SA2747CE at the Kansas city FSDO.
 My contact info is Tom Downey 1-360-202-0961 or nc19143(at)comcast.net
http://www.whidbey.com/fairchild-nc19143/
  --- In
				Re: Technical Data
				Posted: Mon Nov 07, 2011 11:18 pm
				by Tom_Downey
				'Attention Jeremy Harris  >>>
 Your 165 modification package is on its way to your FSDO.. attention Peter L Rouse
 Now here is the catch? the package is for a F-24-G taken out of my aircraft's records. Your aircraft is a F-24-C8C there may be a problem.. we'll see.. wait and hope, we'll see what your FSDO thinks.
 --- In
 > --- In
				Re: Technical Data
				Posted: Tue Nov 08, 2011 12:35 am
				by Jeremy Harris
				'Thanks Tom, I appreciate the help. I have been trying to find any and all info, hopefully I can come up with enough pertinent material to satisfy our friends at the FAA.
 Sent: Monday, November 7, 2011 9:18 PM
 Subject: [fairchildclub] Re: Technical Data
 Now here is the catch… the package is for a F-24-G taken out of my aircraft's records. Your aircraft is a F-24-C8C there may be a problem.. we'll see.. wait and hope, we'll see what your FSDO thinks.
 --- In
 > --- In
