Aeromatic Prop, 200 HP redline on PT26
Posted: Thu Aug 18, 2011 10:53 am
'I brought my "new" PT26 back from Hayward, CA to its new Home at 7B3, Hampton, NH and find that the 2600 foot strip with trees at the end is bit tight on takeoff with what apparently is a cruise prop. I'm planning to install a "new" 220 Aeromatic prop when Mark Denest does the annual October. Some questions:
1. Has anyone got a PT19 or PT26 with the Aeromatic on a 200 HP ranger? What change in performance numbers did you get?
2. Is this prop on the Type Certificate, or does one have to get an STC?
3. What is the appropriate red line RPM for initial take off on the Ranger engine?
4. Any other comments, suggestions?
Jeff Clark'
Jeff Clark'
